Rebooted host now HA won't boot
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[13:31:03] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2021-02-07 13:31:18 ERROR (MainThread) [homeassistant.config] Package zigbee2mqtt setup failed. Integration input_number Integration 'input_number' not found. (See /config/packages/zigbee2mqtt.yaml:1).
2021-02-07 13:31:18 ERROR (MainThread) [homeassistant.config] Package zigbee2mqtt setup failed. Integration input_text Integration 'input_text' not found. (See /config/packages/zigbee2mqtt.yaml:1).
2021-02-07 13:31:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-02-07 13:31:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for remote_homeassistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-02-07 13:31:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-02-07 13:31:18 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for logbook:  we are unable to resolve (sub)dependency person
2021-02-07 13:31:18 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for alarmo:  we are unable to resolve (sub)dependency person
2021-02-07 13:31:18 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for hacs:  we are unable to resolve (sub)dependency person
2021-02-07 13:31:18 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for default_config:  we are unable to resolve (sub)dependency person
2021-02-07 13:31:18 ERROR (MainThread) [root] Uncaught exception
  File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main
    return _run_code(code, main_globals, None,
  File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code
    exec(code, run_globals)
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 320, in <module>
    sys.exit(main())
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 312, in main
    exit_code = runner.run(runtime_conf)
  File "/usr/src/homeassistant/homeassistant/runner.py", line 117, in run
    return asyncio.run(setup_and_run_hass(runtime_config))
  File "/usr/local/lib/python3.8/asyncio/runners.py", line 44, in run
    return loop.run_until_complete(main)
  File "/usr/local/lib/python3.8/asyncio/base_events.py", line 616, in run_until_complete
    return future.result()
  File "/usr/src/homeassistant/homeassistant/runner.py", line 106, in setup_and_run_hass
    hass = await bootstrap.async_setup_hass(runtime_config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 122, in async_setup_hass
    await async_from_config_dict(config_dict, hass) is not None
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 234, in async_from_config_dict
    await _async_set_up_integrations(hass, config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 464, in _async_set_up_integrations
    for dep in itg.all_dependencies:
  File "/usr/src/homeassistant/homeassistant/loader.py", line 373, in all_dependencies
    raise RuntimeError("Dependencies not resolved!")
RuntimeError: Dependencies not resolved!
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
After experiencing this error, I rebooted the host, and the front end won’t come back up?! I can SSH in and see the above in the ha core logs command.
Any ideas?!
Thank you!!!
Did another reboot got this:
[fix-attrs.d] done.
[15:26:56] INFO: Update udev information
[cont-init.d] done.
[services.d] done.
~ $ ha core logs
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
2021-02-07 15:27:10 ERROR (MainThread) [homeassistant.config] Package zigbee2mqtt setup failed. Integration input_number Integration 'input_number' not found. (See /config/packages/zigbee2mqtt.yaml:1).
2021-02-07 15:27:10 ERROR (MainThread) [homeassistant.config] Package zigbee2mqtt setup failed. Integration input_text Integration 'input_text' not found. (See /config/packages/zigbee2mqtt.yaml:1).
2021-02-07 15:27:11 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-02-07 15:27:11 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-02-07 15:27:11 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for remote_homeassistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2021-02-07 15:27:11 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for logbook:  we are unable to resolve (sub)dependency person
2021-02-07 15:27:11 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for alarmo:  we are unable to resolve (sub)dependency person
2021-02-07 15:27:11 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for hacs:  we are unable to resolve (sub)dependency person
2021-02-07 15:27:11 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for default_config:  we are unable to resolve (sub)dependency person
2021-02-07 15:27:11 ERROR (MainThread) [root] Uncaught exception
    sys.exit(main())
I have recent snapshots and restoring them isn’t working either. I’m guessing the supervisor is borked and the snapshots don’t contain the files to repair the underlying problem? I am running ‘ha su repair’ and so far it’s just saying ‘processing’. No sign of any other activity. Anyone know if I’m on the right track?!
Have you tried disabling your third party integrations? Might be a good first step but I’m not sure whether it’ll help.
