still waiting on a new stick and usb cable to potentially improve the situation but it still dumps …
$ tac /home/homeassistant/.homeassistant/OZW_Log.txt |more
2017-08-28 12:14:14.621 Detail, Node037, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchBinaryCmd_Get (Node=37): 0x01, 0x0d, 0x00, 0x13, 0x25, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x02, 0x25,
0xd6, 0x7b
2017-08-28 12:14:14.621 Detail, Node037, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchBinaryCmd_Set (Node=37): 0x01, 0x0e, 0x00, 0x13, 0x25, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x25, 0x01, 0x00,
0x25, 0xd5, 0x79
2017-08-28 12:14:14.621 Info, Node037, SwitchBinary::Set - Setting node 37 to Off
2017-08-28 12:14:14.621 Info, Node037, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch Rear - 0 - 2 - False
2017-08-28 12:14:14.620 Detail, Node037, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Get (Node=37): 0x01, 0x0d, 0x00, 0x13, 0x25, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x02, 0x25,
0xd4, 0x7a
2017-08-28 12:14:14.620 Detail, Node037, Queuing (Send) MultiChannel Encapsulated (instance=3): SwitchBinaryCmd_Set (Node=37): 0x01, 0x0e, 0x00, 0x13, 0x25, 0x07, 0x60, 0x0d, 0x01, 0x02, 0x25, 0x01, 0x00,
0x25, 0xd3, 0x7c
2017-08-28 12:14:14.620 Info, Node037, SwitchBinary::Set - Setting node 37 to Off
2017-08-28 12:14:14.620 Info, Node037, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch Front - 0 - 3 - False
2017-08-28 12:14:14.494 Detail, Node019, Notification: ValueChanged
2017-08-28 12:14:14.494 Detail, Node019, Changes to this value are not verified
2017-08-28 12:14:14.494 Detail, Node019, Refreshed Value: old value=52, new value=53, type=decimal
2017-08-28 12:14:14.494 Info, Node019, Received SensorMultiLevel report from node 19, instance 1, Luminance: value=53lux
2017-08-28 12:14:14.494 Detail, Node019, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x13, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x00, 0x35, 0xea
2017-08-28 12:14:13.745 Detail, Node028, Notification: ValueChanged
2017-08-28 12:14:13.745 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2017-08-28 12:14:13.739 Detail, Node028, Notification: ValueChanged
2017-08-28 12:14:13.739 Detail, Node028, Changes to this value are not verified
2017-08-28 12:14:13.739 Detail, Node028, Refreshed Value: old value=0.647, new value=0.578, type=decimal
2017-08-28 12:14:13.739 Info, Node028, Received Meter report from node 28: Power=0.578W
2017-08-28 12:14:13.739 Detail, Node028, Refreshed Value: old value=false, new value=false, type=bool
2017-08-28 12:14:13.739 Detail, Node028, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x02, 0x42, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-08-28 12:14:13.739 Info, Raw: 0x98, 0x81, 0xb2, 0xb8, 0x43, 0x3a, 0x72, 0x55, 0xc4, 0x24, 0xa3, 0x0e, 0x54, 0x5d, 0x7a, 0xc4, 0xc2, 0xa0, 0x24, 0x45, 0x64, 0xe4, 0xcb, 0x99, 0xc2, 0x3f, 0xbc, 0x33, 0
x4d, 0xb6, 0x2c, 0xa4, 0xd6, 0x44, 0x18
2017-08-28 12:14:13.739 Detail, Node028, Received: 0x01, 0x28, 0x00, 0x04, 0x00, 0x1c, 0x22, 0x98, 0x81, 0xb2, 0xb8, 0x43, 0x3a, 0x72, 0x55, 0xc4, 0x24, 0xa3, 0x0e, 0x54, 0x5d, 0x7a, 0xc4, 0xc2, 0xa0, 0
x24, 0x45, 0x64, 0xe4, 0xcb, 0x99, 0xc2, 0x3f, 0xbc, 0x33, 0x4d, 0xb6, 0x2c, 0xa4, 0xd6, 0x44, 0x18
2017-08-28 12:14:13.660 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-08-28 12:14:13.660 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x0d, 0xe7
2017-08-28 12:14:13.530 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-28 12:14:13.530 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-28 12:14:13.520 Info, Node028, Sending (Command) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x1c, 0x0a, 0x98, 0x80, 0x3f, 0x03, 0xaa, 0x86, 0x64, 0xf5
, 0x5f, 0x4f, 0x05, 0x01, 0x66:
2017-08-28 12:14:13.520 Info, NONCES: 0x42, 0x10, 0xa3, 0x32, 0x7e, 0x42, 0xc0, 0x2e
2017-08-28 12:14:13.520 Info, NONCES: 0xcd, 0x20, 0xed, 0xf9, 0xd8, 0x51, 0x46, 0xac
2017-08-28 12:14:13.520 Info, NONCES: 0xeb, 0xde, 0x89, 0x12, 0x3b, 0x01, 0x78, 0xe0
2017-08-28 12:14:13.520 Info, NONCES: 0xb0, 0xfc, 0x43, 0x7c, 0x47, 0x60, 0x4a, 0xd9
2017-08-28 12:14:13.520 Info, NONCES: 0xd4, 0xf0, 0xca, 0xf6, 0xf1, 0x6e, 0x9e, 0x8d
2017-08-28 12:14:13.520 Info, NONCES: 0xa6, 0xcc, 0xa8, 0x0c, 0x2c, 0xb8, 0x63, 0x4c
2017-08-28 12:14:13.520 Info, NONCES: 0xce, 0x91, 0x8a, 0x94, 0xaf, 0x26, 0x5c, 0x77
2017-08-28 12:14:13.520 Info, NONCES: 0x3f, 0x03, 0xaa, 0x86, 0x64, 0xf5, 0x5f, 0x4f
2017-08-28 12:14:13.520 Info, Node028, Received SecurityCmd_NonceGet from node 28
2017-08-28 12:14:13.520 Detail, Node028, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x1c, 0x02, 0x98, 0x40, 0x35
2017-08-28 12:14:10.743 Detail, Node028, Notification: ValueChanged
2017-08-28 12:14:10.742 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2017-08-28 12:14:10.739 Detail, Node028, Notification: ValueChanged
2017-08-28 12:14:10.739 Detail, Node028, Changes to this value are not verified
2017-08-28 12:14:10.739 Detail, Node028, Refreshed Value: old value=0.612, new value=0.647, type=decimal
2017-08-28 12:14:10.739 Info, Node028, Received Meter report from node 28: Power=0.647W
2017-08-28 12:14:10.739 Detail, Node028, Refreshed Value: old value=false, new value=false, type=bool
2017-08-28 12:14:10.739 Detail, Node028, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x02, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-08-28 12:14:10.739 Info, Raw: 0x98, 0x81, 0x54, 0x12, 0x6b, 0x33, 0xc5, 0x84, 0x83, 0x70, 0xfe, 0x1e, 0xc2, 0xe9, 0xd8, 0x17, 0x48, 0xf8, 0x07, 0x4d, 0x54, 0x9c, 0x76, 0x71, 0x08, 0x42, 0x5d, 0x88, 0
xdf, 0xc1, 0x3c, 0x1d, 0x1d, 0x3c, 0xe8
2017-08-28 12:14:10.739 Detail, Node028, Received: 0x01, 0x28, 0x00, 0x04, 0x00, 0x1c, 0x22, 0x98, 0x81, 0x54, 0x12, 0x6b, 0x33, 0xc5, 0x84, 0x83, 0x70, 0xfe, 0x1e, 0xc2, 0xe9, 0xd8, 0x17, 0x48, 0xf8, 0
x07, 0x4d, 0x54, 0x9c, 0x76, 0x71, 0x08, 0x42, 0x5d, 0x88, 0xdf, 0xc1, 0x3c, 0x1d, 0x1d, 0x3c, 0xe8
2017-08-28 12:14:10.660 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-08-28 12:14:10.660 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x0d, 0xe7
2017-08-28 12:14:10.530 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-28 12:14:10.530 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-28 12:14:10.520 Info, Node028, Sending (Command) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x1c, 0x0a, 0x98, 0x80, 0x42, 0x10, 0xa3, 0x32, 0x7e, 0x42
, 0xc0, 0x2e, 0x05, 0x01, 0xe6:
2017-08-28 12:14:10.520 Info, NONCES: 0x42, 0x10, 0xa3, 0x32, 0x7e, 0x42, 0xc0, 0x2e
2017-08-28 12:14:10.520 Info, NONCES: 0xcd, 0x20, 0xed, 0xf9, 0xd8, 0x51, 0x46, 0xac
2017-08-28 12:14:10.520 Info, NONCES: 0xeb, 0xde, 0x89, 0x12, 0x3b, 0x01, 0x78, 0xe0
2017-08-28 12:14:10.520 Info, NONCES: 0xb0, 0xfc, 0x43, 0x7c, 0x47, 0x60, 0x4a, 0xd9
2017-08-28 12:14:10.520 Info, NONCES: 0xd4, 0xf0, 0xca, 0xf6, 0xf1, 0x6e, 0x9e, 0x8d
2017-08-28 12:14:10.520 Info, NONCES: 0xa6, 0xcc, 0xa8, 0x0c, 0x2c, 0xb8, 0x63, 0x4c
2017-08-28 12:14:10.520 Info, NONCES: 0xce, 0x91, 0x8a, 0x94, 0xaf, 0x26, 0x5c, 0x77
2017-08-28 12:14:10.520 Info, NONCES: 0xa8, 0x9c, 0x41, 0x5d, 0xb6, 0xcc, 0x4b, 0x1c
2017-08-28 12:14:10.520 Info, Node028, Received SecurityCmd_NonceGet from node 28
2017-08-28 12:14:10.520 Detail, Node028, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x1c, 0x02, 0x98, 0x40, 0x35
2017-08-28 12:14:07.754 Detail, Node028, Notification: ValueChanged
2017-08-28 12:14:07.753 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2017-08-28 12:14:07.749 Detail, Node028, Notification: ValueChanged
2017-08-28 12:14:07.749 Detail, Node028, Changes to this value are not verified
2017-08-28 12:14:07.749 Detail, Node028, Refreshed Value: old value=0.651, new value=0.612, type=decimal
2017-08-28 12:14:07.749 Info, Node028, Received Meter report from node 28: Power=0.612W
2017-08-28 12:14:07.749 Detail, Node028, Refreshed Value: old value=false, new value=false, type=bool
2017-08-28 12:14:07.749 Detail, Node028, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x74, 0x00, 0x00, 0x02, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-08-28 12:14:07.749 Info, Raw: 0x98, 0x81, 0x38, 0xed, 0x98, 0xd5, 0x02, 0xef, 0x50, 0x45, 0x48, 0x3b, 0xb3, 0x9b, 0x12, 0x8d, 0xf5, 0x5e, 0xe2, 0x9f, 0xd2, 0xa5, 0xf9, 0x95, 0x26, 0xcd, 0x5b, 0x09, 0
xae, 0x91, 0xca, 0x50, 0x8b, 0xee, 0xe4
2017-08-28 12:14:07.749 Detail, Node028, Received: 0x01, 0x28, 0x00, 0x04, 0x00, 0x1c, 0x22, 0x98, 0x81, 0x38, 0xed, 0x98, 0xd5, 0x02, 0xef, 0x50, 0x45, 0x48, 0x3b, 0xb3, 0x9b, 0x12, 0x8d, 0xf5, 0x5e, 0
xe2, 0x9f, 0xd2, 0xa5, 0xf9, 0x95, 0x26, 0xcd, 0x5b, 0x09, 0xae, 0x91, 0xca, 0x50, 0x8b, 0xee, 0xe4
2017-08-28 12:14:07.663 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-08-28 12:14:07.663 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x0d, 0xe7
2017-08-28 12:14:07.530 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-28 12:14:07.530 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-28 12:14:07.520 Info, Node028, Sending (Command) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x1c, 0x0a, 0x98, 0x80, 0xcd, 0x20, 0xed, 0xf9, 0xd8, 0x51
, 0x46, 0xac, 0x05, 0x01, 0x6d:
2017-08-28 12:14:07.520 Info, NONCES: 0x57, 0x20, 0x1b, 0x8c, 0x7d, 0x22, 0x00, 0xa3
2017-08-28 12:14:07.520 Info, NONCES: 0xcd, 0x20, 0xed, 0xf9, 0xd8, 0x51, 0x46, 0xac
2017-08-28 12:14:07.520 Info, NONCES: 0xeb, 0xde, 0x89, 0x12, 0x3b, 0x01, 0x78, 0xe0
2017-08-28 12:14:07.520 Info, NONCES: 0xb0, 0xfc, 0x43, 0x7c, 0x47, 0x60, 0x4a, 0xd9
2017-08-28 12:14:07.520 Info, NONCES: 0xd4, 0xf0, 0xca, 0xf6, 0xf1, 0x6e, 0x9e, 0x8d
2017-08-28 12:14:07.520 Info, NONCES: 0xa6, 0xcc, 0xa8, 0x0c, 0x2c, 0xb8, 0x63, 0x4c
2017-08-28 12:14:07.520 Info, NONCES: 0xce, 0x91, 0x8a, 0x94, 0xaf, 0x26, 0x5c, 0x77
2017-08-28 12:14:07.520 Info, NONCES: 0xa8, 0x9c, 0x41, 0x5d, 0xb6, 0xcc, 0x4b, 0x1c
2017-08-28 12:14:07.520 Info, Node028, Received SecurityCmd_NonceGet from node 28
2017-08-28 12:14:07.520 Detail, Node028, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x1c, 0x02, 0x98, 0x40, 0x35
2017-08-28 12:13:58.933 Detail, Node018, Notification: ValueChanged
2017-08-28 12:13:58.933 Detail, Node018, Changes to this value are not verified
2017-08-28 12:13:58.933 Detail, Node018, Refreshed Value: old value=26.3, new value=26.3, type=decimal
2017-08-28 12:13:58.933 Info, Node018, Received SensorMultiLevel report from node 18, instance 1, Temperature: value=26.3C
tac /home/homeassistant/.homeassistant/home-assistant.log |more
2017-08-28 12:14:18 INFO (MainThread) [homeassistant.components.http] Serving /api/camera_proxy/camera.baby_cam to 192.168.1.11 (auth: False)
2017-08-28 12:14:18 INFO (Thread-14) [homeassistant.components.device_tracker.nmap_tracker] nmap scan successful
2017-08-28 12:14:18 INFO (Thread-14) [homeassistant.components.device_tracker.nmap_tracker] Scanning…
2017-08-28 12:14:17 INFO (Thread-2) [homeassistant.components.device_tracker.ddwrt] Checking ARP
2017-08-28 12:14:16 INFO (Thread-15) [plexapi] GET http://192.168.1.250:32400/status/sessions?X-Plex-Token=TOKEN
2017-08-28 12:14:16 INFO (Thread-15) [plexapi] GET http://192.168.1.250:32400/clients?X-Plex-Token=TOKEN
2017-08-28 12:14:15 DEBUG (Thread-24) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2017-08-28 12:14:14 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139901994500896: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state automation.light__li
vingroom__lights__off=on; last_triggered=2017-08-28T12:13:15.197134+01:00, icon=mdi:arrow-right-drop-circle, friendly_name=Light - Livingroom - Lights - Off @ 2017-08-28T04:00:20.512689+01:00>, ‘new_state
‘: <state automation.light__livingroom__lights__off=on; last_triggered=2017-08-28T12:14:14.767578+01:00, icon=mdi:arrow-right-drop-circle, friendly_name=Light - Livingroom - Lights - Off @ 2017-08-28T04:0
0:20.512689+01:00>, ‘entity_id’: ‘automation.light__livingroom__lights__off’}, ‘event_type’: ‘state_changed’, ‘time_fired’: datetime.datetime(2017, 8, 28, 11, 14, 14, 767695, tzinfo=)}, ‘id’: 2}
2017-08-28 12:14:14 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139900443644872: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state automation.light__li
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state automation.light__livingroom__lights__off=on; last_triggered=2017-08-28T12:14:14.767578+01
:00, icon=mdi:arrow-right-drop-circle, friendly_name=Light - Livingroom - Lights - Off @ 2017-08-28T04:00:20.512689+01:00>, old_state=<state automation.light__livingroom__lights__off=on; last_triggered=20
17-08-28T12:13:15.197134+01:00, icon=mdi:arrow-right-drop-circle, friendly_name=Light - Livingroom - Lights - Off @ 2017-08-28T04:00:20.512689+01:00>, entity_id=automation.light__livingroom__lights__off>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139902139377424-255>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139902139377424-257>
2017-08-28 12:14:14 DEBUG (Thread-20) [phue] GET /api/A7ob0zolUiMr1jRdEzhRENiE6T4WBvx0Tg8DaFuC None
2017-08-28 12:14:14 DEBUG (Thread-19) [phue] [[{‘success’: {’/lights/22/state/alert’: ‘none’}}, {‘success’: {’/lights/22/state/on’: False}}]]
2017-08-28 12:14:14 DEBUG (Thread-19) [phue] PUT /api/A7ob0zolUiMr1jRdEzhRENiE6T4WBvx0Tg8DaFuC/lights/22/state {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-19) [phue] {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-4) [phue] [[{‘success’: {‘/lights/10/state/alert’: ‘none’}}, {‘success’: {‘/lights/10/state/on’: False}}]]
2017-08-28 12:14:14 DEBUG (Thread-4) [phue] PUT /api/A7ob0zolUiMr1jRdEzhRENiE6T4WBvx0Tg8DaFuC/lights/10/state {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-4) [phue] {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-11) [phue] [[{‘success’: {‘/lights/11/state/alert’: ‘none’}}, {‘success’: {‘/lights/11/state/on’: False}}]]
2017-08-28 12:14:14 DEBUG (Thread-11) [phue] PUT /api/A7ob0zolUiMr1jRdEzhRENiE6T4WBvx0Tg8DaFuC/lights/11/state {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-11) [phue] {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-9) [phue] [[{‘success’: {‘/lights/12/state/alert’: ‘none’}}, {‘success’: {‘/lights/12/state/on’: False}}]]
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139902139377424-256>
2017-08-28 12:14:14 DEBUG (Thread-9) [phue] PUT /api/A7ob0zolUiMr1jRdEzhRENiE6T4WBvx0Tg8DaFuC/lights/12/state {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 DEBUG (Thread-9) [phue] {‘on’: False, ‘alert’: ‘none’}
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=light, service_call_id=139902139377424-257, service_data=entity_id=[‘light.corner_lamp_1’, ‘light.cor
ner_lamp_2’, ‘light.corner_lamp_3’, ‘light.livingroom_floor_lamp’], service=turn_off>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service_call_id=139902139377424-256, service_data=entity_id=[‘switch.livingroom_switch_front’
, ‘switch.livingroom_switch_rear’], service=turn_off>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=homeassistant, service_call_id=139902139377424-255, service_data=entity_id=['switch.livingroom_switch
front’, ‘switch.livingroom_switch_rear’, ‘light.corner_lamp_1’, ‘light.corner_lamp_2’, ‘light.corner_lamp_3’, ‘light.livingroom_floor_lamp’], service=turn_off>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.helpers.script] Script Light - Livingroom - Lights - Off: Executing step call service
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.helpers.script] Script Light - Livingroom - Lights - Off: Running script
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event logbook_entry[L]: message=has been triggered, domain=automation, entity_id=automation.light__livingroom__lights__off, name=Li
ght - Livingroom - Lights - Off>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.components.automation] Executing Light - Livingroom - Lights - Off
2017-08-28 12:14:14 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139901994500896: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state sensor.livingroom_se
nsor_luminance=52.0; unit_of_measurement=lux, icon=mdi:brightness-7, new_entity_id=sensor.livingroom_sensor_luminance, value_instance=1, old_entity_id=sensor.livingroom_sensor_luminance_19_3, node_id=19,
value_index=3, friendly_name=Livingroom Light Level @ 2017-08-28T12:13:15.037174+01:00>, ‘new_state’: <state sensor.livingroom_sensor_luminance=53.0; unit_of_measurement=lux, icon=mdi:brightness-7, new_en
tity_id=sensor.livingroom_sensor_luminance, value_instance=1, old_entity_id=sensor.livingroom_sensor_luminance_19_3, node_id=19, value_index=3, friendly_name=Livingroom Light Level @ 2017-08-28T12:14:14.6
02043+01:00>, ‘entity_id’: ‘sensor.livingroom_sensor_luminance’}, ‘event_type’: ‘state_changed’, ‘time_fired’: datetime.datetime(2017, 8, 28, 11, 14, 14, 602070, tzinfo=)}, ‘id’: 2}
2017-08-28 12:14:14 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139901994500896: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state zwave.livingroom_sen
sor=CacheLoad; old_entity_id=zwave.livingroom_sensor_19, is_ready=False, receivedCnt=677, friendly_name=Livingroom Sensor, retries=0, product_name=FGMS001 Motion Sensor, averageRequestRTT=0, capabilities=
{‘beaming’, ‘routing’}, manufacturer_name=FIBARO System, is_zwave_plus=False, receivedUnsolicited=677, sentTS=2017-08-28 04:00:36:756 , is_awake=True, sentCnt=1, receivedDups=15, query_stage=CacheLoad, is
info_received=True, sentFailed=1, averageResponseRTT=0, max_baud_rate=40000, battery_level=92, node_id=19, is_failed=False, wake_up_interval=7200, lastRequestRTT=0, node_name=Livingroom Sensor, lastRespo
nseRTT=0, receivedTS=2017-08-28 12:13:14:928 , new_entity_id=zwave.livingroom_sensor @ 2017-08-28T04:52:30.747697+01:00>, ‘new_state’: <state zwave.livingroom_sensor=CacheLoad; old_entity_id=zwave.livingr
oom_sensor_19, is_ready=False, receivedCnt=678, friendly_name=Livingroom Sensor, retries=0, product_name=FGMS001 Motion Sensor, averageRequestRTT=0, capabilities={‘beaming’, ‘routing’}, manufacturer_name=
FIBARO System, is_zwave_plus=False, receivedUnsolicited=678, sentTS=2017-08-28 04:00:36:756 , is_awake=True, sentCnt=1, receivedDups=15, query_stage=CacheLoad, is_info_received=True, sentFailed=1, average
ResponseRTT=0, max_baud_rate=40000, battery_level=92, node_id=19, is_failed=False, wake_up_interval=7200, lastRequestRTT=0, node_name=Livingroom Sensor, lastResponseRTT=0, receivedTS=2017-08-28 12:14:14:4
94 , new_entity_id=zwave.livingroom_sensor @ 2017-08-28T04:52:30.747697+01:00>, ‘entity_id’: ‘zwave.livingroom_sensor’}, ‘event_type’: ‘state_changed’, ‘time_fired’: datetime.datetime(2017, 8, 28, 11, 14,
14, 598857, tzinfo=)}, ‘id’: 2}
2017-08-28 12:14:14 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139900443644872: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state sensor.livingroom_se
2017-08-28 12:14:14 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139900443644872: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state zwave.livingroom_sen
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state sensor.livingroom_sensor_luminance=53.0; unit_of_measurement=lux, icon=mdi:brightness-7, n
ew_entity_id=sensor.livingroom_sensor_luminance, value_instance=1, old_entity_id=sensor.livingroom_sensor_luminance_19_3, node_id=19, value_index=3, friendly_name=Livingroom Light Level @ 2017-08-28T12:14
:14.602043+01:00>, old_state=<state sensor.livingroom_sensor_luminance=52.0; unit_of_measurement=lux, icon=mdi:brightness-7, new_entity_id=sensor.livingroom_sensor_luminance, value_instance=1, old_entity
id=sensor.livingroom_sensor_luminance_19_3, node_id=19, value_index=3, friendly_name=Livingroom Light Level @ 2017-08-28T12:13:15.037174+01:00>, entity_id=sensor.livingroom_sensor_luminance>
2017-08-28 12:14:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: new_state=<state zwave.livingroom_sensor=CacheLoad; old_entity_id=zwave.livingroom_sensor_19, is_ready=Fals
e, receivedCnt=678, friendly_name=Livingroom Sensor, retries=0, product_name=FGMS001 Motion Sensor, averageRequestRTT=0, capabilities={‘beaming’, ‘routing’}, manufacturer_name=FIBARO System, is_zwave_plus
=False, receivedUnsolicited=678, sentTS=2017-08-28 04:00:36:756 , is_awake=True, sentCnt=1, receivedDups=15, query_stage=CacheLoad, is_info_received=True, sentFailed=1, averageResponseRTT=0, max_baud_rate
=40000, battery_level=92, node_id=19, is_failed=False, wake_up_interval=7200, lastRequestRTT=0, node_name=Livingroom Sensor, lastResponseRTT=0, receivedTS=2017-08-28 12:14:14:494 , new_entity_id=zwave.liv
ingroom_sensor @ 2017-08-28T04:52:30.747697+01:00>, old_state=<state zwave.livingroom_sensor=CacheLoad; old_entity_id=zwave.livingroom_sensor_19, is_ready=False, receivedCnt=677, friendly_name=Livingroom
Sensor, retries=0, product_name=FGMS001 Motion Sensor, averageRequestRTT=0, capabilities={‘beaming’, ‘routing’}, manufacturer_name=FIBARO System, is_zwave_plus=False, receivedUnsolicited=677, sentTS=2017-
08-28 04:00:36:756 , is_awake=True, sentCnt=1, receivedDups=15, query_stage=CacheLoad, is_info_received=True, sentFailed=1, averageResponseRTT=0, max_baud_rate=40000, battery_level=92, node_id=19, is_fail
ed=False, wake_up_interval=7200, lastRequestRTT=0, node_name=Livingroom Sensor, lastResponseRTT=0, receivedTS=2017-08-28 12:13:14:928 , new_entity_id=zwave.livingroom_sensor @ 2017-08-28T04:52:30.747697+0
1:00>, entity_id=zwave.livingroom_sensor>
2017-08-28 12:14:14 INFO (Thread-5) [homeassistant.components.sensor.command_line] Running command: ssl-cert-check -b -c /home/homeassistant/fullchain.pem | awk ‘{ print $NF }’
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] notif_callback : end
2017-08-28 12:14:14 DEBUG (Dummy-25) [openzwave] Z-Wave Notification ValueChanged : {‘homeId’: 4194397412, ‘nodeId’: 19, ‘notificationType’: ‘ValueChanged’, ‘valueId’: {‘value’: 53.0, ‘genre’: ‘User’, ‘no
deId’: 19, ‘type’: ‘Decimal’, ‘label’: ‘Luminance’, ‘readOnly’: True, ‘commandClass’: ‘COMMAND_CLASS_SENSOR_MULTILEVEL’, ‘instance’: 1, ‘index’: 3, ‘id’: 72057594361692210, ‘homeId’: 4194397412, ‘units’:
‘lux’}}
2017-08-28 12:14:14 DEBUG (Dummy-25) [openzwave] zwcallback args=[{‘homeId’: 4194397412, ‘nodeId’: 19, ‘notificationType’: ‘ValueChanged’, ‘valueId’: {‘value’: 53.0, ‘genre’: ‘User’, ‘nodeId’: 19, ‘type’:
‘Decimal’, ‘label’: ‘Luminance’, ‘readOnly’: True, ‘commandClass’: ‘COMMAND_CLASS_SENSOR_MULTILEVEL’, ‘instance’: 1, ‘index’: 3, ‘id’: 72057594361692210, ‘homeId’: 4194397412, ‘units’: ‘lux’}}]
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] notif_callback : call callback context
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] addValueId : Notification : {‘homeId’: 4194397412, ‘nodeId’: 19, ‘notificationType’: ‘ValueChanged’, ‘valueId’: {‘value’: 53.0, ‘genre’: ‘User’, 'nodeId
': 19, ‘type’: ‘Decimal’, ‘label’: ‘Luminance’, ‘readOnly’: True, ‘commandClass’: ‘COMMAND_CLASS_SENSOR_MULTILEVEL’, ‘instance’: 1, ‘index’: 3, ‘id’: 72057594361692210, ‘homeId’: 4194397412, ‘units’: 'lux
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] addValueId : GetCommandClassId : 49, GetType : 2
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] addValueId : ValueID : 72057594361692210
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] notif_callback : Notification type : 2, nodeId : 19
2017-08-28 12:14:14 DEBUG (Dummy-25) [libopenzwave] notif_callback : new notification
2017-08-28 12:14:13 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 139901994500896: Sending {‘type’: ‘event’, ‘event’: {‘origin’: ‘LOCAL’, ‘data’: {‘old_state’: <state sensor.aeotec_zw075
smart_switch_gen5_current_4=0.07; unit_of_measurement=A, power_consumption=0.647, icon=mdi:mdi:power-socket, new_entity_id=sensor.aeotec_zw075_smart_switch_gen5_current, value_instance=1, hidden=True, old
entity_id=sensor.aeotec_zw075_smart_switch_gen5_current_28_20, node_id=28, value_index=20, friendly_name=Aeotec ZW075 Smart Switch Gen5 Current @ 2017-08-28T12:14:10.857208+01:00>, ‘new_state’: <state se
nsor.aeotec_zw075_smart_switch_gen5_current_4=0.07; unit_of_measurement=A, power_consumption=0.578, icon=mdi:mdi:power-socket, new_entity_id=sensor.aeotec_zw075_smart_switch_gen5_current, value_instance=1
, hidden=True, old_entity_id=sensor.aeotec_zw075_smart_switch_gen5_current_28_20, node_id=28, value_index=20, friendly_name=Aeotec ZW075 Smart Switch Gen5 Current @ 2017-08-28T12:14:13.861081+01:00>, ‘ent
ity_id’: ‘sensor.aeotec_zw075_smart_switch_gen5_current_4’}, ‘event_type’: ‘state_changed’, ‘time_fired’: datetime.datetime(2017, 8, 28, 11, 14, 13, 861095, tzinfo=)}, ‘id’: 2}
smart_switch_gen5_voltage_4=251.41; unit_of_measurement=V, power_consumption=0.647, icon=mdi:mdi:power-socket, new_entity_id=sensor.aeotec_zw075_smart_switch_gen5_voltage, value_instance=1, hidden=True, o
ld_entity_id=sensor.aeotec_zw075_smart_switch_gen5_voltage_28_16, node_id=28, value_index=16, friendly_name=Aeotec ZW075 Smart Switch Gen5 Voltage @ 2017-08-28T12:14:10.855564+01:00>, ‘new_state’: <state
sensor.aeotec_zw075_smart_switch_gen5_voltage_4=251.41; unit_of_measurement=V, power_consumption=0.578, icon=mdi:mdi:power-socket, new_entity_id=sensor.aeotec_zw075_smart_switch_gen5_voltage, value_instan
ce=1, hidden=True, old_entity_id=sensor.aeotec_zw075_smart_switch_gen5_voltage_28_16, node_id=28, value_index=16, friendly_name=Aeotec ZW075 Smart Switch Gen5 Voltage @ 2017-08-28T12:14:13.859630+01:00>,
‘entity_id’: ‘sensor.aeotec_zw075_smart_switch_gen5_voltage_4’}, ‘event_type’: ‘state_changed’, ‘time_fired’: datetime.datetime(2017, 8, 28, 11, 14, 13, 859647, tzinfo=)}, ‘id’: 2}
smart_switch_gen5_previous_reading_7=2130327.5; unit_of_measurement=W, power_consumption=0.647, icon=mdi:mdi:power-socket, new_entity_id=sensor.aeotec_zw075_smart_switch_gen5_previous_reading, value_insta
nce=1, hidden=True, old_entity_id=sensor.aeotec_zw075_smart_switch_gen5_previous_reading_28_9, node_id=28, value_index=9, friendly_name=Aeotec ZW075 Smart Switch Gen5 Previous Reading @ 2017-08-28T12:14:1
0.854148+01:00>, ‘new_state’: <state sensor.aeotec_zw075_smart_switch_gen5_previous_reading_7=2130327.5; unit_of_measurement=W, power_consumption=0.578, icon=mdi:mdi:power-socket, new_entity_id=sensor.aeo
tec_zw075_smart_switch_gen5_previous_reading, value_instance=1, hidden=True, old_entity_id=sensor.aeotec_zw075_smart_switch_gen5_previous_reading_28_9, node_id=28, value_index=9, friendly_name=Aeotec ZW07
