14 Jul 09:51:07 - [info] [cronplus:30 mins before sunrise] System Time Change Detected - refreshing schedules! If the system time was not changed then this typically occurs due to blocking code elsewhere in your application
14 Jul 09:51:07 - [info] [cronplus:sunrise and sunset and pt] System Time Change Detected - refreshing schedules! If the system time was not changed then this typically occurs due to blocking code elsewhere in your application
14 Jul 09:51:07 - [info] [cronplus:Every 15 mins on Sat and Sun] System Time Change Detected - refreshing schedules! If the system time was not changed then this typically occurs due to blocking code elsewhere in your application
14 Jul 09:51:07 - [info] [cronplus:Every 15 mins on MON-FRI 16:00-23:59] System Time Change Detected - refreshing schedules! If the system time was not changed then this typically occurs due to blocking code elsewhere in your application
Wow, that was painful. The only way to cure it was to re-install browser-mod (after i’d removed it) to be able to deregister the 3372 devices via Developer Tools > Actions.
Then delete the integration and finally, delete it from HACS. I won’t be using that tool again.
FYI: I did NOT have ‘auto register’ new browsers enabled.
