do you know a zigbee switch which is capable of:
- working as a router
- controlling “backlight_mode” attribute (control the light indicator on the switch - I would like to turn it off in bedroom)
- working without N wire
- working with Home Assistant
I have bought 2 so far, but neither of them can fulfil all my requirements:
) it is a router
) the light indicator setting cannot be changed - it is always on (if the bulb is off, the indicator shines white, if the bulb is on, the indicator shines green)
) works without N wire
) working with Home Assistant
) it is just end device
) the light indicator setting can be changed
) works without N wire, but sometimes bulbs flash
