I thought I’d share my findings an hopefully in turn benefit from other members findings on Smart Plugs & Bulbs that can be purchased in the UK and successfully flashed with Tuya-convert
Below is some information on items I’ve bought and successfully flashed with tuya-convert
Annoopsyche Smart Plug
Make: ANOOPSYCHE
Model: UK1D
Purchased From: Amazon
My Purchase Price: £16.99 (£19.99 before discount) (2 Pack)
Purchase Date: 10/10/19
Energy Monitoring: YES
Amp Rating: 13A
Dimensions: Width = 56mm x Depth = 33.5mm (ex. pins) x Dept 56.5mm (inc. pins)
Good Points: 13A Rating, Energy monitoring indication at very low wattage & good accuracy
Bad Points: Button on bottom is not ideal location
Avatar Smart plug
Make: Avatar
Model: AWP14H
My Purchase Price: £12.99 (Pack of 2 - £16.99 before discount)
Purchase Date: 15/02/20
Amp Rating: 10A
Dimensions: Width = 57.2mm x Depth = 32.5mm (ex. pins) x Depth 55.4mm (inc. pins)
Good Points: Button on side (rather than bottom)
Bad Points: Only 10A Rating, bigger than some (just interferes with switch on some sockets)
ConnectBeat Smart Plug
Make: ConnectBeat
Model: TP24Y
My Purchase Price: £9
Purchase Date: 17/12/19
Amp Rating: 10A
Dimensions: Width = 57.5mm x Depth = 32.5mm (ex. pins) x Dept 55.3mm (inc. pins)
Home Assistant Entity ID: switch.105572022cf432df4683
Recognised & Working with ConBee II USB Dongle / deconz:
Slitinto Smart Plug
Make: Slitinto (Same as Jules V)
Model: NX-SM112
My Purchase Price: £6.99 (£8.99 before £2 discount)
Purchase Date: 18/12/19
Amp Rating: 16A
Dimensions: Width = 49mm x Height = 61mm x Depth = 32.3mm (ex. pins) x Depth 55.5mm (inc. pins)
Good Points: 16A Rating, good shape / size (does NOT interfere with socket On / Off switch
Bad Points: No longer available on Amazon UK
Jules V Smart Plug
Make: Jules V
Model: NX-SM112
My Purchase Price: £17.99 (2 Pack)
Purchase Date: 02/07/19
Amp Rating: 16A (3520W)
Ousfot Smart Bulb
Make: OUSFOT
Model: 2AKB-Q9
Type: 2700K + RGB Colour Changing & Dimmable
Fitting: E27
My Purchase Price: £12.59 (Lightning Deal) (2 Pack)
Purchase Date: 25/12/19
Dimensions: Length = 131mm Width = 70mm
Rated Wattage: 10W
Tested Wattage (Max): 5W
Lumen Rating: 900lm
Energy Monitoring: NO
Good Points: Cheap, Low power usage
Bad Points: Colours & white could be brighter, rather large in size
A couple of items I was NOT successful with flashing
Generic Colour Bulb
https://www.amazon.co.uk/gp/product/B0778PZG9F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Make: Generic / Non Branded
Model: LE7 (B0778PZG9F)
Type: RGB Colour Changing & Dimmable
Fitting: E27
Dimensions: Length = 111mm Width = 54.5mm
Rated Wattage: 6W (Box Label & Amazon Listing) / 7W (Box)
Tested Wattage (Max): 6W
Tested Wattage (Off):
My Purchase Price: £6.99 (£9.99 before 30% discount)
Good Points: Well made (Heavy), Inexpensive, Work Well in App
Bad Points: Unable to flash with Tuya-Convert
Infray Smart Plug
Make: Infray
Model: CS10ASUKA
My Purchase Price: £25 (Pack of 4)
Amp Rating: 10A
Dimensions: Width = 57.2mm x Depth = 32.5mm (ex. pins) x Dept 55.4mm (inc. pins)
Good Points: Cheap
Bad Points: Unable to flash with Tuya-Convert . Only 10A Rating
