Recommended smoke detectors - reliability, no false alarms, battery life?
Just tried pairing one of these Nedis alarms with ZHA. It took a few attempts to finish, but in the end it still does not show any entities. Not even battery level. :confused:
heiman smoke ws2sa-5, it’s not zigbee but wifi, but it seems pretty good to me (with esphome you could make it BLE)
Available on amazon and other places, it can be reprogrammed with esphome and is pretty good, see my pull request, I have it working for a pretty good amount of time, it works and with proper mods to software (don’t enable API! it’s damn slow!) it will do what you want it to do.
EDIT: this heiman thing is exactly similar in everything (except shelly uses esp32) to the shelly plus smoke. I have both of them, but wasn’t able to reprogram with esphome the shelly one, since the pinout is hidden for the GPIO0 and I don’t want to unsolder something, since shelly can do also mqtt
I picked up the Frient smoke alarms a couple of months ago. Well supported in z2m. No false positives inside our apartment including about 4 metres from the stove. But also so far — no positives.
I just bought one of these. Pairing in ZHA went fine. But then no sensors showed up in Home Assistant. It appeared in ZHA, but there’s nothing you could do with it. Returned it within an hour.
