I received on my notifications 2 new notifications :Alexa Media Reauthentication Required and the other ,Integration requires reconfiguration.
I follow the link and both send me to the Integrations where I found 2 new integrations to reconfigure. I press the button to configure and nothing happens on Both. At the same time I receive from Amazon a OTP .My echo become unavailable .I have NABUCASA.I already update Custom_Components but didn’t solved .I’m running Home Assistant 2022.8.7 ,Supervisor 2022.08.5 ,Operating System 8.5
Frontend 20220802.0 - latest
Any idea about what is happening is welcome.
I have the same setup and are receiving the same notifications…I enter the details and OTP, it goes away and then comes back the next day. This has happened for the past two days now. I guess Amazon have changed something…I am in the UK if anyone has similar experiences…
Mine renewed fine too…But only lasted 24 hours before it popped up again…I thought is might be related to issues I was having with Spotify too…But it looks like they have changed the way API calls in Spotipy so that is bricked at the moment
i reconfigured, needed to register a new app with a new code, then verify on amazon, come back to ha, login to amazon page, verify the code i get on my mobile phone.
then go to automations, run a notification to alexa, booooom another HA notification pops up that i need to reconfigure.
did it.
automation again, test - boooooom again the notification…
tried again two times and now it doesnt even work. when i enter the codes and come back to HA it says this configuration needs to visit an external website…
every time there is something not working, i got it.
but mostly i got one on top - thats how my life works.
So i did what you said, BUT i had to reconfigure it properly to be able to remove it completely.
and then i added it completely new.
and immediately after adding i had the notification again…
and guess what?
i now have 2 of those not working integrations:
isnt that something funny?
i am really laughing now.
(in the meantime i altered my automations so that they go over IFTTT to Alexa, because i slightly had the feeling that this wont be solved fast here)
EDIT: i also now got 6 devices authorized in Amazon and have no clue how to erase them… every time i try again, there is one device more showing up there. (the counter at least, the device i cannot see)
i apreciate if you got more ideas as i am quite new to HA and myself have no ideas left to try.
Sorry, if you already did this, but did you first delete the integration by clicking on the three dots and then choosing ‘Delete’? You will now need to this for both instances before trying to re-add. Also, make sure that you restart HA after deleting, and before re-adding.
I’ve been having the same problems for the last few days. Could just work on it again now.
I’m now using the built-in 2FA from Media Player (Configuration · custom-components/alexa_media_player Wiki · GitHub) and it works.
Just copy the code from the Amazon website into the field in Media Player when you reconfigure, hit send and verify with an OTP.
Reboot.
When it comes back, let it sit for a while (for me it was 2 days, but only because I didn’t have time to take care of it before) and then hit reconfigure again.
For me it just said “reauthenticated” and that was it.
