I have been reconfiguring my record settings and now it is almost usefull and possible to work with, but I have an issue with my climate entities.
When I add my climate entities I get 3 values from them - Heating, Current temperature and Target temperature.
The Heating value makes no sense in my case, since I can not set it to cool or anything else and it will always follow the value of Current temperature, although with that slight difference that the graph will have a almost solid field filled below the graph for the Heating values.
This solid field distort the graphs, so I have to click off the Heating values every time I need to use them.
Is there a way to either disable the filling of the area below the graph or simply disable these Heating values all together?
Ok, thou in my History i don’t have any “Fill” … and i really can’t remember if i have “removed it” my self or what
PS: i think you can use configuration.yaml
History:
exclude:
entities:
PS: i didnt use correct indented here, just example( it's pretty much like recorder, include/exclude)
wow… yeah , mine looks like the 2nd pic … the above looks pretty weird … you can remove them (Heating Values) from History, but still have in Recorder, with above … then maybe use a graph-card for the Heating-values, and see how it behave there
ok, but still looks crazy, as it seems to “fill/color” everything, i mean even the “top” in the middle, that is also present below (maybe living-room temperature)
ahh ok, you had 4 “disabled” in 2nd pic, i see now … remove those in config…yaml , until you figure out why they behave like this … 1 of the reasons i don’t like History … they just shuffle everything into 1 graph, as long as it’s same “measurement” … so % is a mix of Humidity and Batteri level , CPU, DISK etc … lol, i try to avoid clicking on History
I guess making a Grafana view or a lovelace card would give some more control over the graphs.
It might be the solution I choose if noone else can get rid of that fill.
I can’t remove the disabled graphs, since they are automatically part of the climate entities.
Thanks for trying though.
It Depends which “Device_Class” it is, most likely your Climate falls under “Temperature” Device_class … you can find out looking in configuration/device&entities, then click the devices tab find the device, click it, and click “Download Diagnostic” … Or in “core.entity_registry” … but be careful in there, is a “running” system file
