Recurring todo with due date & time
Description
This will create a recurring todo item that always appear on a specified list. When the item is marked complete, it will be recreated to be due x days from now (at y time).
It will perform the following:
  1. When the list is modified in any way this automation will trigger, wait 20 seconds, then
  2. Removes the ‘item name’ if it is completed in the todo list, then
  3. If the ‘item name’ does not exist in the todo list as either a complete or incomplete item (this prevents duplicates):
    1. Adds a new entry for ‘item name’ set for the number of days specified away from today, with the specifies due time
Note: in order for the todo to first display, make any modification (add/remove/complete an item on the list) after saving this automation
This is a modification of the blueprint by @bakinbits found here.
blueprint:
  description: >-
    Setup a recurring todo to always appear on a specified list. Performs:
      2. Removes the 'item name' if it is completed in the todo list, then
      3. If the 'item name' does not exist in the todo list as an incomplete item (this prevents duplicates):
          1. Adds a new entry for 'item name' set for the number of days specified away from today, with the specifie due time
    ### Note: in order for the todo to first display, make any modification (add/remove/complete an item on the list) after saving this automation
  domain: automation
  input:
    taskList:
      description: List containing recurring tasks (must exist)
      selector:
        entity:
          filter:
            - domain: todo
    taskName:
      description: The name that represents the to-do item.
    taskDescription:
      description: A more complete description of the to-do item than provided by the item name.
      default: " "
    recurDays:
      name: Days until task is due
      description: How often should task repeat once completed (number of days)
      selector:
        number:
          min: 1
          max: 365
    recurTime:
      name: Recur time (24hr)
      description: What time should the task repeat in 24 hour time (HH:MM:SS format)
      selector:
        time:
      default: 12:00:00
mode: restart
max_exceeded: silent
  - platform: state
    entity_id:
      - !input "taskList"
condition: []
  - delay: "00:00:20"
    alias: Wait 20 seconds before modifying list, in case change was an accident
  - variables:
      taskList: !input "taskList"
      taskName: !input "taskName"
      taskDescription: !input "taskDescription"
      recurDays: !input "recurDays"
      recurTime: !input "recurTime"
    alias: Set Task Details
  - service: todo.get_items
    metadata: {}
      status:
        - completed
      entity_id: "{{ taskList }}"
    response_variable: completedTasks
    alias: Get all completedTasks
  - if:
      - condition: template
        value_template: >-
          {{taskName in completedTasks[taskList]['items'] |
          map(attribute='summary') | list}}
        alias: If todo exists and is completed
    then:
      - service: todo.remove_item
        metadata: {}
          item: "{{ taskName }}"
    alias: If todo is completed, remove it from list
  - alias: Get allTasks
    metadata: {}
      status:
        - completed
        - needs_action
    response_variable: allTasks
  - alias: If todo is not in the list already, add it with new due date and time
    if:
      - alias: "Todo does not exist"
        condition: template
        value_template: >-
          {{ taskName not in allTasks[taskList]['items'] |
    then:
      - variables:
          newDueDate: "{{ (now() + timedelta(days=recurDays)).strftime('%Y-%m-%d') }}"
      - service: todo.add_item
        metadata: {}
          description: "{{ taskDescription }}"
          due_datetime: "{{ newDueDate }} {{ recurTime }}"
This is amazing, just what I needed :slight_smile:
Big thank you for this was just about to write one!
Hi everyone,
I’m encountering an issue with this automation blueprint. The automation fails with the following error:
Invalid datetime specified: 2025-01-18 43200 for dictionary value @ data[‘due_datetime’]
The completed task gets deleted, but not recreated.
EDIT: I had to define „Recur time (24hr)“, now it is working.
Here’s a screenshot of the error:
