I’m thinking to buy a Proscenic 811GB robot vacuum cleaner. Can anyone tell e whether this will be controllable via hass.io?
Regards,
Dave
Regards,
Dave
I have actually ordered the Proscenic 811GB and it should arrive sometime this week. I’m still new with hass.io but i will try my best and give you an update.
ok so it arrived today and i googled a bit, it is possible to controll it with http or udp packages
udp:
here
and here
and here
for http you have to get a bit more creative but you can do more with it. I used Charles Proxy to analyze the html traffic of the smartphone app and was able to create a curl command to output every detail you can find in the app (like battery, firmware, status).
hope this helped you a little
After a long google-ing i found python script for controlling some basic functionality …
https://github.com/markomannux/pyproscenic/blob/master/proscenic/proscenic.py
I hope some of the gurus here to create a “plugin” for it, just like for the Xiaomi robot one, because Proscenic is even smarter and it will soon flood the market. Especially with a price of 199$ for US in AliExpress (for the 790T wich is their best model for now).
I ordered one 790T, but it is still in transit status …
Why don’t you share the links (and all of your progress)? I think this could help the developers to introduce an official platform for Proscenic, which provides more controls and information …
i just wrote some little bash scripts so far and implemented them in node-red for now
but sure, i will share what i’ve got so far
like i mentioned you have to use some tool like chales Proxy to get the cookie for the curl command
curl -H 'User-Agent: blapp' -H 'Accept-Language: en' -H 'Accept: application/json' -H 'IsLogin: 1' -H 'Cookie: <youre cookie string here>' -H 'Host: bl-app-eu.robotbona.com' --data "nonce_str=<youre data string here>" --compressed 'http://bl-app-eu.robotbona.com/baole-web/index/getMyDefaultRobotInfo.do'
so this will get us the json with all the current information about the little robot
the json looks something like this (i removed some of the data for obvious reasons)
"data": {
"robot": {
"authCode": "<hidden>",
"battery": "100",
"cameraUid": "<hidden>",
"deviceId": "<hidden>",
"deviceIp": "",
"devicePort": "",
"firmwareVer": "{\"esp32\":\"1.0.36\",\"mcu\":\"2.4.139(500)\"}",
"funDefine": "",
"map": "0",
"param": "",
"robotId": "<hidden>",
"robotImg": "http://baole-release.robotbona.com/7c030ac59f5e4b258725982a2616d9f8.png",
"robotModel": "811GB",
"robotName": "proscenic robotic 811GB",
"updateMode": "",
"updateModule": "",
"updatePro": "",
"workState": "6"
"update": {
"isNeedUpdate": "0"
"workRecords": [
"clearArea": "0",
"clearId": "<hidden>",
"clearSTime": "<hidden>",
"clearTime": <hidden>
"clearArea": "0",
"clearArea": "0",
"clearArea": "0",
"msg": "ok",
"result": "0",
"version": "1.0.0"
clear time is in secounds and clearSTime is the start time with date (yyyy-mm-dd hh:mm:ss)
i still havn’t figured out all modes, but so far i know the following: 0 = does nothing, 1 = working, 5 = charging
what is interesting is the fact that its based on a esp32/nodemcu and could in theory be flashed with custom firmware.
i periodically let the bash script store the json file in a ramdisk and from there i have several other scripts i can run (monitoring battery, current mode, how long the last clean was,…). I also use a telegram bot to start, stop and get the battery lvl of the robot because you can only use the app on one device at a time and we are multiple ppl in this house. My next step will be to put everythin in a single python script which is easy to use.
I will post if i have found other things i can do with it.
Try this one:
Posting to follow the topic. I am trying to use the same kind of protocol for my 790T.
First, thanks for the bl-app-eu.robotbona.com url, I was only able to find the IP of the Proscenic server (47.91.67.181).
Regarding Json data, I was able to find it using a sniffer on the app. It seemes to be the same synthax for both 811gb and 790t:
variable cmd = 0
And for the mopping rate:
variable seq = 0
objet value :
For now, I am trying to execute the Json command to start (basically) the robot, but only face failures:
synthax should be something like:
type=command¶m=control&authCode="xxx"&deviceIp="192.168.1.X"&devicePort="1234"&targetId="yyyyy"&targetType="1"&type=seq¶m=value&transitCmd="100"
I guess the cookie you are talking about is the first request I saw, sending the information to the robot containing the appKey, token, userId etc, right?
Hello guys,
After a long time i find this integration. But i can’t find the Local_Key. i have also 790t.
