I am trying to set up a vibration sensor to monitor the vibrations of a kid with epilepsy at night. I am using a Sonoff Dongle Plus E as a coordinator.
I have bought an aqara vibration sensor and I am really disappointed with it since it does not report vibrations “in real time”.
I have set up vibration_timeout as 3 and the sensitivity to High but the sensor will just report vibration one time, then wait for the vibration_timeout value to pass, and then go to clear for almost 90 seconds until it is able to report again. I have tested this by taking the aqara device in my hand and shaking it for several seconds.
See here, in all of those events I have shaken my hand for at least 10 seconds but the event duration is always 3 seconds.
This (ignored) issue seems to be related: DJT11LM adjustable vibration timeout vs fixed 60 sec lockout · Issue #12444 · Koenkk/zigbee2mqtt · GitHub
I also can not use the tilt sensors since they do not report anything until the device is still again.
Does anyone have a recommendation for a reliable vibration sensor? Does not have to necessarily be a battery-powered one, but it should be able to continually report the vibration (with a configurable vibration timeout).
Thank you very very much!
