I wonder is this possible to reload integration automatically?
Maybe using pyscript.
Any suggestion would be appreciate.
Thanks a lot.
Thanks a lot.
If you search for “reload integration” you will find a few posts including:
etc.
But you should not have to reload an integration if it is working properly. In other words: why do you need to reload the integration?
Thank @MaxK. I have a security camera in the living, which is usually off when a family member is at home. I set up to turn the camera on (using a switch) when no one is at home. But, sometimes, HA does not load the camera properly.
