I have a ZB smart switch with measurement function (Tongou TO-Q-SY1-JZT) successfully connected to the ZHA. I have set up automation to protect the circuit from exceeding the 20A load limit.
When I reload the ZHA, this automation is triggered, and power is cut off. When I try to switch on with a physical button or in HA, immediately the automation is triggered again. It makes a pointless loop. In the logs you can see this: Turned off triggered by automation Protection: overcurrent triggered by numeric state of Tongou switch and meter Current
The other automations (voltage, wattage) are not triggered during the ZHA reload. Overcurrent automation is not triggered when the HA reboots. Does anyone have an idea why this is happening and how to mitigate it?
First youâll do well to use numeric state instead of device triggers in the future because if you replace a device you have to edit your automation if you use entity_id and replace the device as long as the entity is is the same on your new device your automation keeps truckinâ. That said.
Your device is probably going unavailable or unknown during the cycle and then getting the new state. (and interpreted as above number in your trigger) You can accommodate those in your automation using ânot from xâ exclusions in the state trigger in the automation.
Run a trace of the automation. Post the trace and someone will help.
* Triggered by the numeric state of sensor.tongou_switch_and_meter_current at 28 March 2024 at 06:14:31
* Turn off <unknown entity>
* (switch.tongou_switch_and_meter_switch) turned off
* Finished at 28 March 2024 at 06:14:31 (runtime: 0.12 seconds)
Encouraged by the indicated post, I have added conditions. It now looks like this:
alias: Test
description: ""
- type: current
platform: device
device_id: 9e119f85db9bf8a2982e01bcc20bff37
entity_id: 897beedf270490d7160cdbf2fe04b2ca
domain: sensor
above: 20
condition:
- condition: template
value_template: "{{ trigger.from_state.state not in ['unknown', 'unavailable'] }}"
value_template: "{{ trigger.to_state.state not in ['unknown', 'unavailable'] }}"
value_template: "{{ trigger.from_state.state != trigger.to_state.state}}"
- type: turn_off
entity_id: 1080cb0e5e07cf3987727569f6f44929
domain: switch
mode: single
Reloading ZHA still triggers the Current protection automation but no longer triggers the circuit breaker.
* Triggered by the numeric state of sensor.tongou_switch_and_meter_current at 28 March 2024 at 13:27:36
* Test Test if template renders a value equal to true
* Stopped because a condition failed at 28 March 2024 at 13:27:36 (runtime: 0.00 seconds)
I have just started my HA adventure. Please advise if my modification of the automation code is correct.
Promising. That means itâs ignoring the flip from unknown or unavailable to a number now.
Now you need to see if your automation works for what itâs designed to do.
You can use developer tools to temporarily override the device state to force it over your trigger value to see if it works. You should expect it to trigger but this time because it was not coming from unavailable or unknown and to something over your trigger value⌠Pop.
Unfortunately, the overcurrent automation I created is not working. I have tested several scenarios and despite exceeding the set limits (A), the power supply is not cut off. The log shows that the device immediately updates the status when the electric current increases. You can see this on the sensor readings screen.
However, if you set up automation based on energy transfer (W), it works as expected. Iâve done several trials with the trip thresholds set in Watts and it has been as expected each time. It is worth noting that this automation is not sensitive to ZHA reload. So I set the trip threshold to 5700W, which corresponds roughly to 25A [at 230V] taking into account the power factor, and left it that way.
I donât understand why the automation based on energy transfer is not problematic and the one based on current is indeed. Perhaps it has to do with something being wrong with the ZHA quirk for the meter. https://community.home-assistant.io/t/energy-sensor-shows-summation-delivered-multiplied-by-100/709373
