Fist add the RM mini 3 via Integrations page in Home Assistant. Then…
Learn the command:
script:
learn_stair_lift:
sequence:
- service: remote.learn_command
entity_id: remote.stair_remote # Example entity id
device: stair_lift
command: up
Send the command with num_repeats:
script:
send_stair_lift:
sequence:
- service: remote.send_command
device: stair_lift
command: up
num_repeats: 200 # The number of repetitions you want
If you send me the code, we can make it better. The first bytes represent the number of repetitions. We can put this at the limit to reduce the amount of packets sent.
Edit: I just remembered something. If you are going to send long codes, it is better to wait for the next release of the python-broadlink library before doing critical operations like this. There is a problem of extra repetitions for long codes like yours. It will be resolved soon, I already created the PR.
Apologies if it wasn’t clear from my side. In effect I can generate the code, but when I add it to my configuration.yaml it doesn’t work seems the code is not correct…
The config looks ok, but I see that you are using the same code to turn it on and off. This can be problematic. Most devices use a toggle bit in the code. You need to learn two codes, one for each command.
Thanks, basically it’s exactly the same code. In effect I use then the on integrated into a script and only use the on. Looking to the older answers and the Panasonic example the code should be much longer, I searched for a while without any success. Broadlink told me as well they currently don’t support this action…
i have a similar issue turning on my pellet stove, and have nearly given up. i can control the temp and fan but cant figure out the 2sec power press to start and stop it. Do you mind sharing how you got the codes? Everytime i try the long press a different sequence appears.
Sorry, I didn’t find any code for pellet stoves. If you find the codes in a crowd-sourced database (IRDB, LIRC etc), there are several modules out there that can help with conversions:
@aceindy thanks, i need to find out if i do have an Evo board in my stove. I think i do (Fuoco Delia), but need to confirm. Also i am new to this, when u mentioned the ESP01, is it possible to use the M5stack, as i bought a couple for another infrared prj (which didnt pan out)?
Hi felipediel
I missed your message.
My code isn’t for a Panasonic,I was just taking the example.My equipment is a heater,so the broadlink reads the code I sent you, but it doesn’t work. …
Thanks. The code I have sent was the result of the long press, but it doesn’t take all the code. In parallel I opened a ticket within Broadlink, but they just said they don’t support long-press.
I believe we would be able to repeat the payload manually if we would be able to identify the part of the code, but…
