I have PC computer without Wake On Lan function, but I need to have option to remotely run computer. The best option for me would have button/card/etc on panel in Home Assistant where I have option to see is computer running with option to turn on or turn off computer. If no from HA, maybe only from Linux CLI, I have HA on Docker on Debian.
I can check is computer running for example with ping. I can turn off computer via ssh and shutdown. But I don’t have any idea how to turn on… My motherboard model is: GA-B75M-D3V (rev. 1.0) Overview | Motherboard - GIGABYTE Global Can I connect some module (or something) inside PC to remotely trigger start? Something to send same signal as from normal button on case? I don’t have any idea.
Thanks for answers! Proposition from @koying sounds very good, but probably it doesn’t work. I enabled “PXE boot ROM” option in BIOS and no result. So I tried to enable option in OS:
sudo ethtool --change eth0 wol g
Cannot set new wake-on-lan settings: Operation not supported
not setting wol
What does it mean? I can’t use WoL with this motherboard? I have Ubuntu on that PC, I should install something additional?
Hi, mine doesn’t support WOL as well.
Problem is, the board I’m using is the one for running Home assistant,
It’s an AIO and I’m also using it as dashboard with debian gnome + HA vm under proxmox.
I bought this adapter and I’m not sure how to wake the machine after outage since nothing else can call the wake up command, any ideas?
