Hello all,
I did some changes in my setup and now i want to change / edit the entity_id of a script. As far as i am concerned i cannot do it via the UI.
The changes that i want to make is from script.name_1 to script.name_2
I have managed to change the friendly name of the script via the GUI from Name 1 to Name 2 but is impossible to edit the the entity_id
When i navigate to the entities section is says that the entity is read-only and i cannot make any changes.
thank you in advance.
V
Jonah1970
(Mark)
2
Edit the Script in the UI then click the three-dots to duplicate it and save it with your new name. You can then delete the old script.
I don’t think you can edit the entity_id of a Script from the UI as there is no unique ID.
thanks for the reply.
I have rename it manually via scripts.yaml and it looks ok. i will give it a try to see if it works
else I need to rename 18-20 scripts
oh well if the manual renaming via .yaml is not the solution i will do the duplication and the renaming. i might need a beer for that
thanks again
jwerner
(Jörg Werner)
4
Thanks! Exactly what helped me to fix it.
jakeasmith
(Jake A. Smith)
5
I choose to believe it was the beer that helped you fix it.
Horus
6
I don’t know, what is the underlying problem, but if it is related to Reset / Re-acquire entity_id you might to give it a vote.
