No I do not have an updated doc, someone disected the firmware file and was able to optain this still undocumented command. I figured out the paramter by just trying and a bit of luck
I think the ID part needs to be in the payload body and cannot be supplied in the URL directly.
as usual, reolink don’t furnish some newer documentations to help us for developping when they’ve released new stuff (new cams or newer firmware). At the end, we have to use differents methods or paths to finally obtain informations about the newer or modified commands they’ve added. For me, it’s annoying and very fustrating for developpers because it’s a waste of time and Reolink will have to much take care about this
Regards
You can just wait for 2023.4 to be released
I was really impatient so I implemented a simple rest command which plays a file. You have to modify the id parameter to select the file you want to play…
