But even when I change the channel from 0 to 1,2, or 3, it seems that I always get the motion status of only the first camera.
BTW, this command also works without the “channel” parameter, and still returns the status of the first cam, so I think this is probably the part that I have got wrong?
I’d recommend the integration from fwestenberg. It can be installed through HACS by adding it as a custom repository - https://github.com/fwestenberg/reolink.
Although I did struggle getting it to work through my NVR but after speaking to Reolink support, my NVR didn’t support the functionality.
Hi anyway to let this component work with Home Assistant 0.110.1
I’ve got this error
Invalid config for [sensor.template]: extra keys not allowed @ data[‘sensors’][‘motion_frontdoor’][‘delay_off’]. Got OrderedDict([(‘seconds’, 30)])
value is not allowed for dictionary value @ data[‘sensors’][‘motion_frontdoor’][‘device_class’]. Got ‘motion’. (See ?, line ?).
Here is mine. As you can see it’s slightly different so maybe have a play and see how you go. I am running latest firmware on NVR and cameras and this works without issue.
Interesting I still actively use mine for image snapshot and Google Cloud Vision object processing. Although I use Motioneye for RTSP conversion. Maybe you can have a look into getting your camera into Motioneye and then take a feed from that?
I’m looking into buying the Reolink 4k cameras for our house & integration into HA would be a must, google assitant a nice-to-have. Everything still seemingly working for everyone nicely?
Hi guys,
I’m new to HA, I followed the video I link below for adding my cameras into HA but once I finished, I just see a camera called “camera.NVR.nvrname” with a grey window. I don’t see instead the cams of my NVR. I also tried to define the cams like @roadkill247 suggest but I still can’t find them into entities. On username and password I placed my user and password of the NVR, camera number 01 (as I tried the first one which is plugged into the 01 slot).
