Hi @fwestenberg, thank you for the response.
I tried to use HACS but not sure I understand how exactly, I tried to search on HACS firstly but no repo for reolink, additionally i tried to add a custom repo as integration and used the github url: https://github.com/fwestenberg/reolink but i get a error message: Repostitory structure for v0011 is not compliant
create additional user in reolink camera with admin rights (admin required for full operation, separate user good practise)
Make sure the camera ip does not change.
For the configuration in home assistant. No yaml required.
host = camera ip
Port = default is 80, if you have not changed in the camera
User + pwd = camera user + password
I’m not having any luck with the integration showing up in HA. I’ve been successful in adding the custom repository and get as far as the ability to install v.10. After multiple restarts of HA server I’m never able to see the integration through the regular ‘add Integrations’ procedure. thanks for any help you can provide!
I have a NVR with 5 cameras ,but for some reason only 3 of the 5 cameras will detect motion randomly. What I mean is when I restart HA 3 of the binary motion sensors will work ,but two of them show as unavailable. It’s different each time. The three that do work do detect motion ,but the two that are unavailable do not detect motion even when I try to trigger motion ;however, the rest of the camera does seem to work.
Any idea how to fix this? I did try removing it, restarting and adding it again.
Hey, any ideas how I speed up the refresh of the camera on lovelace? It seems to be every 10 seconds for me at the moment. Adding “camera_view: live” just causes the module to become blank. Any ideas?
same problem, just installed it for the first time. Had some images for a short while and now this error…
2021-01-06 09:01:07 INFO (MainThread) [homeassistant.components.stream] Started stream: rtmp://192.168.98.225:1935/bcs/channel0_main.bcs?channel=0&stream=0&token=caf0d6d031a0950
fwestenberg Great job. Are you planning to add support for 510A and 810A cameras in the near future? I mean the entities for detecting people and vehicles because video and motion detection are great
