Great, got your addon working seems to be a bit quicker then connect it as a platform: generic.
Did you have it working with a Chromecast or a GoogleHub etc?
Hi guys, sorry for not responding for a long time. I have been working on some other stuff, but happy to see people still care for a Reolink integration. About Gmail, it will propably not work with the current integration. This is because the Reolink cam can connect with Gmail, but this HA integration does not. So the event will not be triggered. Also, please check out one of my previous posts about ONVIF events. I think this will the best solution possible.
This is new to me! However, I donāt think itās very charming to poll every x seconds for motion, still prefer to have ONVIF push events. But still better than the old e-mail notifications to HA.
No itās not. I upgraded to 0.102.0 and itās still running. Please explain what is not working.
Proof here:
Hey,
Thanks for this integration! couple questions please:
Stephen
See my previous 4 posts earlier to the one your replied to. It has the errors I was getting when HA starts. I ended up disabling your component for the time being. I havenāt revisited it since as Iāve been busy, so maybe this has been fixed.
It was fixed by pull request #5 on 11-10-2019.
Iāll give it another try later
hey @fwestenberg
thanks a lot for you awesome work !
would you consider having it under HACS (if not making it official)
Hello Ettore,
Iām glad you like it! Iām considering about making it official. Last time I did it took me almost more time to release it than the actual build did.
So with a little helpā¦
Unfortunately I canāt decently code in python, so Iām not sure I could offer you help
I know its a huge time sink, I happened to follow some component āofficialisation processā, and⦠hass maintainers can sometimes be a little āpickyā.
Great news! I decided to implement the GetMdStatus call into the HA integration (and removed the SMTP client). So now the polling interval for Motion detection can be set via the default HA parameter in your config:
camera:
- platform: reolink
host: 192.168.1.20
username: admin
password: !secret reolink
scan_interval: 5
This parameter is only for motion detection polling. The settings are polled every 30 seconds only.
Dear,
canāt get it to work.
What could be wrong?
Error:
Platform error: camera
File "/usr/src/homeassistant/homeassistant/config.py", line 762, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 232, in get_platform
f"{self.pkg_path}.{platform_name}"
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/reolink/camera.py", line 13, in <module>
from custom_components.reolink_dev.ReolinkPyPi.camera import ReolinkApi
ModuleNotFoundError: No module named 'custom_components.reolink_dev'
This is probably because I changed the folder structure and file naming because of the planned release to HA. Please make sure you have the following folders/files in your HA custom_components folder (please ignore the __pycache__, this will be generated as soon as you hit the check configuration button):
Thanks! That solved it.
Issue was with the name of the folder reolink > reolink_dev
Iāve been trying to get this to work for a few days now. Everything checks out until I add this to my config, then I get this error:
Platform error camera.reolink - No module named ācustom_components.reolink_devā
EDIT: Changed the name of the folder to reolink_dev like @Klex1404 mentioned and now I get a different error:
Platform error camera.reolink - No module named ācustom_components.reolink.cameraā
Did you download the latest version?
I downloaded it yesterday. Have there been changes since then?
Just downloaded again and itās the same exact files
My setup:
- platform: reolink
host: 192.168.1.xx
username: !secret reolink_username
password: !secret reolink_password
scan_interval: 5
This works
My setup looks exactly the same as yours. Not sure what I did wrong. Iām on the latest version of HA, could that be it?
