Me too. Could you post the setup in the correct format? Use the </>
You should change
- platform: reolink
to
- platform: reolink_dev
Just did that and now I get:
Platform error camera.reolink_dev - Integration āreolink_devā not found.
Hereās what the files look like:
It works for me with
- platform: reolink
Are the __init__.py
files present in both folders?
I guess this is because in the manifest.json platform is still set to reolink. So both work.
No, when I downloaded the zip file it didnāt contain the init files in any of the folders
Yes in both folders.
Are those files automatically created? Because, like I said, I do not see those files anywhere
Got it. Github didnāt like the empty files. So now there is a comment line in it. I added the __init__.py
files to the git repository.
That did the trick! Thank you sir
Really hope somebody can help you, this HAS to become official (or at least HACSed!)
Iām having some trouble getting this to work. Downloaded today and configured as documented. The custom component loads but no camera entity is created with the below config:
camera:
host: 192.168.1.173
username: admin
password: REDACTED!
scan_interval: 5
The host, username and password are all correct and I can access the camera from the command line on the system running HA.
Any suggestions as to where I should look to lose this?
Thank you in advance.
Regards,
Michal
I stuck to exactly what he had and that worked and mine is connected to the nvr so just got channel=0
Now I just need to work out how to mod this to include channels 0 to 7 and bring up all cameraās
I tried using platform reolink_dev as documented:
2019-12-03 18:10:31 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for reolink_dev which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-03 18:10:31 ERROR (MainThread) [homeassistant.config] Platform error: camera
File "/usr/src/homeassistant/homeassistant/config.py", line 762, in async_process_component_config
platform = p_integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 232, in get_platform
f"{self.pkg_path}.{platform_name}"
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/config/custom_components/reolink/camera.py", line 13, in <module>
from custom_components.reolink_dev.ReolinkPyPi.camera import ReolinkApi
ModuleNotFoundError: No module named 'custom_components.reolink_dev'
and platform reolink since thatās the custom component directory name:
2019-12-03 20:59:02 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for reolink which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-03 20:59:02 ERROR (MainThread) [homeassistant.config] Platform error: camera
Neither worked for me
i made a copy and have both in my custom components
reolink
reolink_dev
seems to be some where in the code he is referencing both
Oh sorry I just re-read your post
Platform needd to be reolink_dev
Custom component folder needs to be reolink_dev
Yepā¦ That did itā¦
Thank you!
Perhaps it would be a good idea to chance the directory name in the github repository to match?
Good to hear.
Now I just need to work out how to fix it to work with the NVR. Or just put a POE switch between the cameras and the NVR so the cams are on the local lan and not just on the NVR local lan
@Harry13 let me know how this goes, as Iām interested in it as well and the NVR just gets in the way!
