I’m using a Global plug that’s integrated with HA via LocalTuya to control lights on a Christmas tree. With the holiday season over, the device has been unplugged and packed away with the decorations. I’ve also disabled the device in the LocalTuya integration. Despite this, I’m seeing repeated error’s in HA logs advising:
OSError: [Errno 113] Connect call failed (‘192.168.86.104’, 6668)
There error repeats continuously, with updates occurring several times an hour. Why I’m I seeing these error’s when the device has been disabled? I thought disabling the device would stop HA from attempting to connect to the device. FWIW - I did restart HA however the errors continue to flood the log. Is there a way to stop HA from recording errors for this device?
Here’s a copy of the error message from the logs. Note, HA was restarted around 10:00 am today…
This error originated from a custom integration.
Logger: custom_components.localtuya.common
Source: custom_components/localtuya/pytuya/__init__.py:1163
Integration: LocalTuya (documentation, issues)
First occurred: 10:51:44 AM (200 occurrences)
Last logged: 2:09:42 PM
[280...6a9] Connect to 192.168.86.104 failed
File "/config/custom_components/localtuya/common.py", line 187, in _make_connection
self._interface = await pytuya.connect(
File "/config/custom_components/localtuya/pytuya/__init__.py", line 1163, in connect
_, protocol = await loop.create_connection(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1064, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1049, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 960, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 500, in sock_connect
return await fut
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 535, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.86.104', 6668)
