Replace zigbee dongle with identical dongle
I have the Sonoff zigbee 3 USB dongle that I suspect may be failing. I would like to replace it with the identical model. What is involved with this? I am using ZHA. I’m running 2024.2 on a RPi
I see links in ZHA about “migrate radio” but am looking for some documentation on what the steps will be - or descriptions from others that have done this.
My situation is that I am remote from the Pi, so would ask a friend to flash the dongle, swap out the old and plug in the new one - provided that 's all he will have to do. Will it be straightforward or will things like rebuilding / re-pairing every device be necessary (requiring physical access to every zigbee device)?
thx,
Ken
Are you sure? If a new dongle makes no difference you’ll have made the situation even more complicated, not having swapped it yourself.
While you’re heading down the right path to replace the dongle, I’m with @Stiltjack. Why do you think it’s failing?
(that - failure of the stick itself js actually one of the least likely failure modes unless you zapped the stick with a arc welder)
I had a zigbee network that has been very stable for several months. It has 8 Third Reality gen 2 smart power monitoring plugs, 4 Sengled power monitoring plugs, 4 various motion sensors and 2 smoke detectors. The house sat empty for several months (i.e. no changes, nothing new added), just HA merrily watching and controlling the house in my absence. (There is also a lot of UPB, Zwave, Yolink devices that continue to run perfectly) Then, in around December the 8 Third Reality plugs all went off line. Then a few days later they came back online, then on and off every few weeks ever since. It realize now, that even when they were on-line - they really were only partially on-line - they could report power levels, but I could not control them (Failed to Send request - Duplicate TSN). Today I noticed this same behaviour with the Sengled devices - they all report power but I cannot control any of them. Looking back, I see now that I haven’t been able to control the sengled for quite some time. The motion sensors work fine. As far as I know the smoke detectors work fine (I haven’t had a fire but they do report status regularly) Sometimes the TR plugs stop transmitting power data for a week or so as well - but the Sengled keep sending power data - the Sengled has never stopped sending power data.
After months of providing information and answering questions from the ZHA team, I’ve pretty much come to the conclusion that the ZHA integration is not at fault here. Yesterday I had a friend go over and we removed one Third Reality plug, did a factory reset and re paired it to the network. No change. I still cannot control it. Pairing took a very long time. We did the testing with the plug 4m from the coordinator (direct line of site). Power cycling the Pi and coordinator has not helped.
So, in a house that sat idle for over 4 months, suddenly 12 zigbee devices stopped accepted commands (which is 100% of the zigbee devices that should be controllable stopped being controllable). All motion devices work fine, power level gets received some of the time. Unless I believe that 12 different devices all went bad at the same time, I’m struggling to find another likely cause. I’ve considered noise in the network - but trouble shooting that (remotely) seems a lot harder than just having a friend (who is an electrical engineer who manages the firmware development team for the Garmin Communications division and also uses HA) - swapping out a dongle as a first test.
I am very open to other options - and while, I have asked this question a few times in various forums in this community, no one to date has any ideas. I’d love to hear your thoughts :slight_smile: and be thrilled to learn if there is something else I can try!
thx,
Ken
Interesting issue. Having partial control as well. Did you notice any difference in the signal on the visualisation tool?
Not really - LQI levels are all less than exciting - but there is just as wide a variety there as there is on the other devices.
I’ve included this table as it’s easier to read than the visualization page
I’m sorry - this must be very frustrating, trying to fix Zigbee from a distance. It’s bad enough when you’re on the spot. :roll_eyes:
I expect you’e done this already, but have you looked at the ZHA energy scan? You should be able to get that remotely - it’s at the bottom of the diagnostics you can download from the ZHA integration page. Mine looks like this:
    "energy_scan": {
      "11": 6.789392891308996,
      "12": 6.789392891308996,
      "13": 6.789392891308996,
      "14": 3.6632469452765037,
      "15": 21.09014924761344,
      "16": 46.26944564832987,
      "17": 19.00785284282869,
      "18": 10.914542804728702,
      "19": 55.9836862725909,
      "20": 65.26028270288712,
      "21": 68.14622793558128,
      "22": 87.33047519856483,
      "23": 85.82097888710312,
      "24": 82.35373987514762,
      "25": 2.84844209578687,
      "26": 70.89933442360993
You can see the amount of noise on each channel, (which includes Zigbee, wi-fi, your neighbour’s wi-fi etc.). Something may have changed in the last four months.
My only other thought is that 4m is quite a long way… :grin:
Ahh okay I’m learning this as well.
In my energy scan it shows this
    "energy_scan": {
      "11": 78.25348754651363,
      "12": 91.05606689948522,
      "13": 88.70042934643088,
      "14": 78.25348754651363,
      "15": 92.95959997754716,
      "16": 21.09014924761344,
      "17": 49.512515447068886,
      "18": 49.512515447068886,
      "19": 46.26944564832987,
      "20": 52.75969252664325,
      "21": 84.164247274957,
      "22": 93.76433891498253,
      "23": 93.76433891498253,
      "24": 73.50699819621309,
      "25": 96.64469941013013,
      "26": 92.95959997754716
Im on channel 25, should I move to channel 16?
Not if it’s working! If it ain’t broke, don’t fix it… :grin:
That’s fair, I get a warning every now and then that I’m in the low 90% utilisation of my network, its a concern but not a problem
So this raises another interesting point. I brought this up with the ZHA team but they had no explanation.
When I try to download the diagnostics I get an error:
When I click on the file I get
At the same time I also get a error in HA that an attempt to log in failed. That issue only happens when the devices are offline (at the very beginning this problem was more intermittent and I could download the diagnostics when everything was running fine (of course!) - but not when it was failing.
(I can’t find anything in the log )
Maybe this is related?
Also 4m = 4 metres :slight_smile:
Yes… On planet Zigbee that’s still quite a long way.
I experienced this when I tried flashing my sonoff zigbee dongle with new firmware; unable to control them but they reported their state promptly when toggling state using the buttons on the plugs. Have you changed the firmware from the original? I fixed it by reverting to the original version and it came back to life.
How is the dongle connected to the Pi? (and what version Pi?)
Pi 4, 8gb, dongle connected via 1.5 m shielded USB cable. Mounted to ensure antenna orientation doesn’t change.
I have not changed it. So it is the same version that they worked with for several months. ZHA is supposed to offer ota firmware updating capability but zha can neither find the devices firmware levels, nor the current level offered by the manufacturer.
Just curious- what other Zigbee devices does your network have and are they working just fine?
Hi
I’ve copied the table from above. This is all my zigbee devices
There are also two battery devices - a moisture sensor for my lawn and a 4 button hand held switch. These aren’t in use over the winter so they continued to send signals or be (presumably) functional until their batteries died last fall. Any device that just sends me signals/status continues to work fine
As I understand the Zigbee protocol, devices dynamically switch between channels during communication to find the clearest channel. You are just selecting the starting channel.
Mine reliably reports when my wife is frying dinner. But never when the chimney flue is closed.
I apologize for asking you to repeat the data in post #4. I do agree with @Stiltjack in that if some devices are working through the dongle, then the dongle is unlikely to be the problem.
It just occurred to me, do you have OTA firmware updates turned on in your configuration.yaml?
I have no experience with this component, but I am wondering if during the long time unattended, automatic updates may have gotten out of sync?
Can your on-site friend take a couple of the Zigbee plugs to their Home Assistant installation to test and update them?
Not sure about this. Devices in a Zigbee network change their connections with one another dynamically, but the channel is selected in the integration. I don’t think ZHA changes channel automatically (like some wi-fi routers, say).
