@Dayve67 Yes that would work. Just remember to use https://
in the configured URL.
Perfect that worked. Just had a problem with my password. json dont like characters in the password.
Thank you
I still have 1.0.3 installed. How do i trigger the update?
@Maaniac Just go to the add-on “store”, in the top right, hit the refresh button. Wait a couple of seconds and the update will pop-up!
Saw someone on twitter suggested Floorplan.
I’d like that one too.
You mean the custom floorplan by @pkozul?
If so I can confirm it works great with hassio already…
You just need to create a www dir in your config dir. All the custom stuff goes in there.
Using the samba addon helps.
I’ve received the suggestion multiple times already.
Agreed. Nevertheless, I could be a run-once add-on that does this for you?
Yes, but at top of this thread you want us to suggest things that is not in the poll, and i could not see anyone in this thread have suggested it before.
It’s a nice idea - I never really thought about using a run-once add-on to install. I will keep this in mind
You’d need to be careful that running a second time by mistake does not trash modified files… and with floorplan there is likely to be modified files. Its not a simple as install the custom files and dropping in a SVG of the floorplan.
I already have logic for that kind of stuff, so that is not really a problem.
Then I fully endorse your suggestion
HAASKA
I can’t seem to make my hass(dot)io installation of homeassistant work with alexa custom skill. The video by Ben at BRUH, indicates we need haaska which is not possible to install on the hass(dot)io flavor of homeassistant.
I’ve seen this really cool looking ‘add-on’ discussed here. I asked if it would work with Hass.IO as all the chat seems to revolve around Hassbian but no one has answered so I figured I’d put it here to see if it can be made into an actual Hass.IO add-on like these other ones above.
Looks great.
But have you tried the Configurator addon. For me this works very good
Is it possible to get the Mysenors gateway component as an add-on for Hassio? I had my RPI3 running Home Assistant set up as a mysensor gateway. To install the gateway on the RPI i would follow: https://www.mysensors.org/build/raspberry. I have now moved to hassio and trying to get this set up again. I read on another topic that in order to get the mysensor gateway set up, would need to install via an add-on.
Thanks in advance!
Maybe add it as a suggestion to the repository?
