Repository: NotoriousBDG Add-Ons (Node-RED, HA Bridge, and Gogs)
When I try to install HA-Bridge from repo (https://github.com/notoriousbdg/hassio-addons) on a fresh install of Hassio HomeAssistant v0.54 on RaspberryPi3, the Install button immediately turns red and supervisor log as follows:
17-10-02 04:08:56 INFO (MainThread) [hassio.addons] Startup application run 0 addons
17-10-02 04:10:18 INFO (SyncWorker_13) [hassio.dock.addon] Start build 27e642c6/armhf-addon-ha-bridge:4.5.6p2
17-10-02 04:10:18 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 422, in start
    resp = yield from self._request_handler(request)
  File "/usr/lib/python3.6/site-packages/aiohttp/web.py", line 306, in _handle
    resp = yield from handler(request)
  File "/usr/lib/python3.6/site-packages/hassio/api/util.py", line 31, in wrap_api
    answer = await method(api, *args, **kwargs)
  File "/usr/lib/python3.6/site-packages/hassio/api/addons.py", line 171, in install
    addon.install(version=version), loop=self.loop)
  File "/usr/lib/python3.6/site-packages/hassio/addons/addon.py", line 443, in install
    if not await self.docker.install(version):
  File "/usr/lib/python3.6/site-packages/hassio/dock/util.py", line 18, in wrap_api
    return await method(api, *args, **kwargs)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 196, in _install
    return self._build(tag)
  File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 209, in _build
    image = self.docker.images.build(**build_env.get_docker_args(tag))
  File "/usr/lib/python3.6/site-packages/docker/models/images.py", line 175, in build
    raise BuildError(chunk['error'])
docker.errors.BuildError: Please provide a source image with `from` prior to run
Is it because on bwsystems github (GitHub - bwssytems/ha-bridge: Home automation bridge that emulates a Philips Hue light system and can control other systems such as a Vera, Harmony Hub, Nest, MiLight bulbs or any other system that has an http/https/tcp/udp interface. This is a compact impl to run on small format computers. This is impl started from this project https://github.com/armzilla/amazon-echo-ha-bridge.) ATTENTION: This requires JDK 1.8 to build?
Has anyone found a fix for this yet?
I’ve been using an alternate install of home assistant (swapped SD cards), rather than HassIO. Installed node-red alongside it, and installed the node-red-contrib-home-assistant package. I didn’t have any luck with the web socket package, but this one appears to work properly.
Loving node red for automations. I’ve now got things set up so that when I’m listening to music in my office with the lights on, and I need to step outside (far enough away that my phone leaves the wifi), the music pauses and the lights go off. When I return, they go back to their initial state. For example, if I’ve got the lights on but I’m not listening to music, it’ll only toggle the lights, and vice versa.
Looking forward to getting the add-on installed on HassIO.
Awesome, thanks for all the hard work on getting this resolved. Appreciate all your efforts. If there is anything we can do on this end (e.g. send chocolate chip cookies) , do let me know.
What do you mean, not sure it is fixed yet?
Can you expand on your setup?
What OS, inside docker? what version of homeassistant and node-red?
Yes, not fixed…was just trying to say THANK YOU for working on the problem. Sorry, post probably wasn’t clear.
No problem I cannot continue as I am dependent on HABridge and it is not fixed so I too will be thankful for homeassistance 0.55 fixing this problem with add-on installation
Thanks for the Node Red add on. I also seem to have the problem with node red.
See log below.
    17-10-08 05:12:41 INFO (SyncWorker_11) [hassio.dock.addon] Start build 27e642c6/armhf-addon-nodered:0.1.2
17-10-08 05:12:41 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/lib/python3.6/http/client.py", line 546, in _get_chunk_left
    chunk_left = self._read_next_chunk_size()
  File "/usr/lib/python3.6/http/client.py", line 513, in _read_next_chunk_size
    return int(line, 16)
ValueError: invalid literal for int() with base 16: b''
  File "/usr/lib/python3.6/http/client.py", line 578, in _readinto_chunked
    chunk_left = self._get_chunk_left()
  File "/usr/lib/python3.6/http/client.py", line 548, in _get_chunk_left
    raise IncompleteRead(b'')
http.client.IncompleteRead: IncompleteRead(0 bytes read)
  File "/usr/lib/python3.6/site-packages/urllib3/response.py", line 302, in _error_catcher
    yield
  File "/usr/lib/python3.6/site-packages/urllib3/response.py", line 384, in read
    data = self._fp.read(amt)
  File "/usr/lib/python3.6/http/client.py", line 449, in read
    n = self.readinto(b)
  File "/usr/lib/python3.6/http/client.py", line 483, in readinto
    return self._readinto_chunked(b)
  File "/usr/lib/python3.6/http/client.py", line 594, in _readinto_chunked
    raise IncompleteRead(bytes(b[0:total_bytes]))
  File "/usr/lib/python3.6/site-packages/hassio/api/addons.py", line 176, in install
  File "/usr/lib/python3.6/site-packages/hassio/addons/addon.py", line 467, in install
  File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 198, in _install
  File "/usr/lib/python3.6/site-packages/hassio/dock/addon.py", line 211, in _build
  File "/usr/lib/python3.6/site-packages/docker/models/images.py", line 173, in build
    for chunk in json_stream(resp):
  File "/usr/lib/python3.6/site-packages/docker/utils/json_stream.py", line 66, in split_buffer
    for data in stream_as_text(stream):
  File "/usr/lib/python3.6/site-packages/docker/utils/json_stream.py", line 22, in stream_as_text
    for data in stream:
  File "/usr/lib/python3.6/site-packages/docker/api/client.py", line 302, in _stream_helper
    data = reader.read(1)
  File "/usr/lib/python3.6/site-packages/urllib3/response.py", line 401, in read
    raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
  File "/usr/lib/python3.6/contextlib.py", line 100, in __exit__
    self.gen.throw(type, value, traceback)
  File "/usr/lib/python3.6/site-packages/urllib3/response.py", line 320, in _error_catcher
    raise ProtocolError('Connection broken: %r' % e, e)
urllib3.exceptions.ProtocolError: ('Connection broken: IncompleteRead(0 bytes read)', IncompleteRead(0 bytes read))
HomeAssistant 0.55 was released this evening but did not fix HABridge AddOn install issue below supervisor log:
When I try to install Ha Bridge Add-on on a fresh install of Hassio with HomeAssistant v0.54 or 0.55 on RaspberryPi3, the Install button turns red immediately the Supervisor log as follows:
17-10-08 10:45:55 INFO (SyncWorker_1) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.55
17-10-08 10:47:17 INFO (SyncWorker_14) [hassio.dock.addon] Start build 27e642c6/armhf-addon-ha-bridge:4.5.6p2
17-10-08 10:47:18 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py”, line 422, in start
File “/usr/lib/python3.6/site-packages/aiohttp/web.py”, line 306, in _handle
File “/usr/lib/python3.6/site-packages/hassio/api/util.py”, line 31, in wrap_api
File “/usr/lib/python3.6/site-packages/hassio/api/addons.py”, line 176, in install
File “/usr/lib/python3.6/site-packages/hassio/addons/addon.py”, line 467, in install
File “/usr/lib/python3.6/site-packages/hassio/dock/util.py”, line 18, in wrap_api
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 55, in run
File “/usr/lib/python3.6/site-packages/hassio/dock/addon.py”, line 198, in _install
File “/usr/lib/python3.6/site-packages/hassio/dock/addon.py”, line 211, in _build
File “/usr/lib/python3.6/site-packages/docker/models/images.py”, line 175, in build
raise BuildError(chunk[‘error’])
docker.errors.BuildError: Please provide a source image with from prior to run
17-10-08 10:47:19 INFO (SyncWorker_6) [hassio.dock.addon] Start build 27e642c6/armhf-addon-ha-bridge:4.5.6p2
17-10-08 10:47:20 ERROR (MainThread) [aiohttp.server] Error handling request
17-10-08 10:47:24 INFO (SyncWorker_5) [hassio.dock.addon] Start build 27e642c6/armhf-addon-ha-bridge:4.5.6p2
17-10-08 10:47:24 ERROR (MainThread) [aiohttp.server] Error handling request
17-10-08 10:48:32 INFO (SyncWorker_0) [hassio.dock.addon] Start build 27e642c6/armhf-addon-ha-bridge:4.5.6p2
17-10-08 10:48:32 ERROR (MainThread) [aiohttp.server] Error handling request
I am running Hassbian 0.53.1 on a raspberry pi 3. I used ssh to connect and install node-red 0.17.5. There are quite a few challenges in settings things up (I didn’t get the correct install directory the first few times around), but eventually I arrived at the right install state.
It’s not running inside docker. I flashed Hassbian using Etcher directly onto the SD card. This was before I knew of HassIO, although I’ve since updated Hassbian. I’m using Samba to access my configuration, and backing it up to my PC.
Announcement:
Big thanks to the following for fixing the install issues with HABridge 4.5.6p2 broken when HomeAssistant 0.54 was released: :clap:
pvizeli
ravensteijn
pi3rr3hassio
d3nnis0
Repo: https://github.com/ravensteijn/hassio-addons
I’ve committed a fix for all of the addons to work with the new build system.
Welcome back from leave…thanks updating.
Is there any chance of making HABridge a docker app instead of build on the fly? and is installed with a pull?
Is it possible to install the Node-RED Dashboard in hass.io via SSH (npm i node-red-dashboard)? If so, run the install command in which directory?
Yes, I plan to do that when I have some free time to work on it.
It’s possible, but it’s fairly complicated. It’s much easier to just install the node from the UI. If you really want to do it via SSH, you’d have to ssh to the hassio host, then launch a bash shell in the Node-RED container, then you can run the commands to install the nodes you wish.
Hi, that’s good news will wait for when you launch the docker image version.
In the interim I have HomeAssistant running in a docker on Raspbian Stretch on the RPi3, do you have any instructions of how to install HABridge in this configuration? do you install HABridge in a separate docker or in the same as HomeAssistant? and do you have the install steps?
I’ve moved everything over to HassIO now that node-red is working again, but I’ve noticed that it doesn’t boot when I restart Home Assistant. I’ve got it set to auto in the configuration. Is this a bug, or do I need to do something to start node-red on boot, like create an automation for it?
[edit] Seeing this in the log after starting HA.
npm ERR! Linux 4.4.50
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" "--" "--userDir" "/data"
npm ERR! node v6.11.0
npm ERR! npm  v3.10.10
npm ERR! code ELIFECYCLE
npm ERR! [email protected] start: `node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script 'node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"'.
npm ERR! Make sure you have the latest version of node.js and npm installed.
npm ERR! If you do, this is most likely a problem with the node-red-docker package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR!     node $NODE_OPTIONS node_modules/node-red/red.js -v $FLOWS "--userDir" "/data"
npm ERR! You can get information on how to open an issue for this project with:
npm ERR!     npm bugs node-red-docker
npm ERR! Or if that isn't available, you can get their info via:
npm ERR!     npm owner ls node-red-docker
npm ERR! There is likely additional logging output above.
npm ERR! Please include the following file with any support request:
npm ERR!     /usr/src/node-red/npm-debug.log
Hi. I would like to thank you so much for the node red add-on. The program is working great and I was lost without it.:open_hands::+1
Not sure what could be causing that. When I reboot my hassio box, it starts up automatically for me.
