[Request] Common or aligned time axis on all history graphs
I’ve started using the below card as a permanent replacement for the History Panel and History Graph Card. These features make it a huge improvement:
  • Easily recreate the existing History Panel with timelines and graphs. Colors can be transferred over so it looks identical and it can be added to the sidebar to mimic existing panel
  • Duration selector at the top to quickly pick timeframes to view
  • Graphs can be panned by dragging the mouse to show more data (all graphs move together)
  • All dates/times line up vertically, which was is a major nuisance with the existing History Panel
  • Entities can be setup manually in YAML so a default, defined view is always immediately ready (similar to the old History Panel)
  • Entities can be added on the fly using the entity picker drop down (this can be pre-filtered to only those entities that are actually recorded in your database with recordedEntitiesOnly: true)
