raphael
(Elliot)
June 6, 2018, 3:54pm
1
Hi guys, new to HA, follow the guide http://ronmar.co/ha/2017/03/10/Ultimate-Alarm-Clock/
Reached an issue but HA error log:
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 174). Please check the docs at Sensor - Home Assistant
my config.yaml
- platform: time_date
display_options:
- 'time'
- input_slider:
alarm_clock_hour:
initial: 6
min: 0
max: 23
step: 1
- alarm_clock_minute:
initial: 15
min: 0
max: 55
step: 5
- input_boolean:
alarm_clock_status:
initial: on
sensors:
alarm_clock_hour:
value_template: "{{ states.input_slider.alarm_clock_hour.state | int }}"
alarm_clock_minute:
value_template: "{{ states.input_slider.alarm_clock_minute.state | int }}"
alarm_clock_time:
value_template: >-
{{ states.sensor.alarm_clock_hour.state }}:
{%- if states.sensor.alarm_clock_minute.state|length == 1 -%}
0
{%- endif -%}
{{ states.sensor.alarm_clock_minute.state }}
alarm_clock_time_long:
value_template: >-
{% if states.sensor.alarm_clock_hour.state|length == 1 -%}
0
{%- endif -%}
0
{%- endif -%}
Not sure where i went wrong. I have check it with yamllint its ok but the error keeps appearing.
Any help would be great. Thanks
If your code above is copied directly from your config, your spacing is incorrect, and input_slider and input_booleans are not sensors.
raphael
(Elliot)
June 6, 2018, 4:02pm
3
I am using spacing for the indents, why is it still wrong?
Do I put my input_slider and input_booleans outside? Like this?
input_boolean:
alarm_clock_status:
initial: on
input_slider:
alarm_clock_hour:
initial: 6
min: 0
max: 23
step: 1
Why the spacing are not showing? I am directly copying and pasting…?
The page you linked to tells you where to put it. You put input_boolean and input_slider in the config.yaml, and the other stuff in the sensors section
you’re using quote and not code blocks?
raphael
(Elliot)
June 6, 2018, 4:09pm
5
I have edited the input_boolean and input_slider to the outside of config.yaml but HA says ‘Unable to find component input_slider’.
display_options:
- 'time'
initial: 15
min: 0
max: 55
step: 5
hline_1:
value_template: hline
hline_2:
sensors:
alarm_clock_hour:
alarm_clock_minute:
alarm_clock_time:
value_template: >-
0
{%- endif -%}
value_template: >-
0
{%- endif -%}
0
{%- endif -%}
config.yaml:
input_slider:
alarm_clock_hour:
initial: 6
min: 0
max: 23
step: 1
alarm_clock_minute:
initial: 15
min: 0
max: 55
step: 5
input_boolean:
alarm_clock_status:
initial: on
display_options:
- 'time'
sensors:
alarm_clock_hour:
value_template: '{{ states.input_slider.alarm_clock_hour.state | int }}'
alarm_clock_minute:
value_template: '{{ states.input_slider.alarm_clock_minute.state | int }}'
alarm_clock_time:
value_template: >-
0
{%- endif -%}
value_template: >-
0
{%- endif -%}
0
{%- endif -%}
Tinkerer
(aka DubhAd on GitHub)
June 6, 2018, 4:13pm
8
It is as easy as reading the documentation for input boolean :
input_boolean:
initial: 15
min: 0
max: 55
step: 5
display_options:
- 'time'
raphael
(Elliot)
June 6, 2018, 4:19pm
9
Sorry guys to put you thru this.
I copy and paste into my config.yaml what you posted but there’s a ‘Component not found: input_slider’ error message.
Is it because they renamed it back to input_number? https://community.home-assistant.io/t/0-57-0-unable-to-find-component-input-slider/31520
You’re following an old guide.
Please read up on the components that you are using.
raphael
(Elliot)
June 6, 2018, 4:22pm
11
So sorry for everything and thank you so much.
