Resol vBus
Hello Everyone,
I’m currently looking at moving from OpenHAB v1.8 over to Home Assistant.
It seems to do everything I need except one thing, OpenHAB has a binding to connect to the Resol controller on my solar hot water service. Anyone know if there is something similar in HA?
Regards,
Josh
try that:
  • platform: command_line
    command: “curl -s /dlx/download/live | jq -r ‘.headersets[0].packets[3].field_values[2].raw_value’”
    name:
    scan_interval: 100
    The json is a kind of weird, therefore you have to play a bit arund to find your values.
regards,
-thomas
Josh, just checking did you manage to get the resol working with home assistant? I am trying to get it working at the moment, but not having any joy.
No I didn’t, the code Thomas suggested only works with the dataloggers, not the vBus LAN gateway.
OK, thanks. I have the DL2 datalogger, but when I try Thomas’ suggestion the unit fails to reboot
I am also interested in getting Resol vbus data to Home Assistant. I’ve an RS232 interface that is connected to my solar controller and I can get data on /dev/ttyUSB0 but I have no idea how to proceed.
Update: https://github.com/danielwippermann/resol-vbus/tree/master/examples/json-live-data-server does exactly what I was looking for. It generates a json which can be accessed via http.
Now I just need to get that json data to home assistant.
I’ve just created a custom_component for ResolVbus, available on https://github.com/epenet/hassResolVbus
I use it with a USB serial adapter connected to a Vitosolic 200 (destination 0x0010, source 0x7321).
Hi
What kind of RS232 adapter are you using and any additional hardware? I’m trying to get raw Vbus data into Homeassistant and thought you couldn’t just use a standard RS232.
Any advice much appreciated.
I am using the adapter that was shipped with the SungoXXL Hardware (some fancy old stuff from last century)
I just picked up an RS232 to USB adapter.
What pins on the DB9 connection do I connect the Vbus pins 9.10 to?
I tried to connect my deltasol BS plus today.
It won’t work.
I use a wellemann vma440 https://www.velleman.eu/products/view/?id=441224 to connect Vbus to USB.
Configuration file are edited to match the addresses for my unit.
Tried to connect TX to pin 9 and RX to pin 10, no flashing LED.
Swapped the pins and RX on pin 9 and TX on pin 10, TX LED flashing.
After a time I get this error:
Log Details (WARNING)
Tue Dec 03 2019 23:10:01 GMT+0100 (CET)
Update of sensor.myresol is taking over 10 seconds.
Any ideas what to do?
Do I need to activate something in Deltasol? Coluldnt find anything in the manual.
Hi Fredrik,
Did you already find a solution for this. I want to read my Deltasol SLL.
No I couldn’t make it work.
Tried several adapters (rs485).
I think you need the curcuit or an adapter for Resol.
I had to make my own circuit to convert vBus signal levels to RS-485.
What circuit do you use??
I have seen some types.
I copied most of the schematic from others and built a PCB to match.
Hi! I have a number of these blank PCB’s at £10 each inc. postage to Europe. Contact me through www.gb3jv.co.uk Justin
do you have any picture?
