Hej guys,
reffering to my topic Scrape sensor for bank exchange rates from XML (below) I would like to report the problem with the REST resource template.
[Scrape sensor for bank exchange rates from XML ]
As I did not change anything in my config and everything was working fine, there must be some issue with the HA updates.
Now I can not restart my HA server, because it is telling me error on line 88 - which had no error before.
Any idea, what is wrong ???
Thanks a lot
resourcee_template is spelled wrong, should be:
resource_template
Hey man,
checked and corrected, my bad…but still not working…
rest:
- resource: https://www.cnb.cz/cs/financni-trhy/devizovy-trh/kurzy-devizoveho-trhu/kurzy-devizoveho-trhu/denni_kurz.xml
scan_interval: 28800
- name: Kurz CZK/EUR
unit_of_measurement: 'CZK/EUR'
device_class: monetary
value_template: "{{ value_json.kurzy.tabulka.radek|selectattr('@kod','eq','EUR')|map(attribute='@kurz')|first|replace(',','.') }}"
- name: Kurz CZK/GBP
unit_of_measurement: 'CZK/GBP'
value_template: "{{ value_json.kurzy.tabulka.radek|selectattr('@kod','eq','GBP')|map(attribute='@kurz')|first|replace(',','.') }}"
- name: Kurz CZK/USD
unit_of_measurement: 'CZK/USD'
value_template: "{{ value_json.kurzy.tabulka.radek|selectattr('@kod','eq','USD')|map(attribute='@kurz')|first|replace(',','.') }}"
- name: Kurz CZK/PLN
unit_of_measurement: 'CZK/PLN'
value_template: "{{ value_json.kurzy.tabulka.radek|selectattr('@kod','eq','PLN')|map(attribute='@kurz')|first|replace(',','.') }}"
- resource_template: https://csob.cz/spa/exrate/exrates/-/date/{{ now().isoformat()[:10] }}/kurzovni-listek.xml
- name: Kurz CSOB CZK EUR
value_template: "{{ (value_json.ExchangeRate.Country|selectattr('@ID','eq','EUR')|first)['FXcashless']['@Sale'] }}"
- name: Kurz CSOB CZK GBP
value_template: "{{ (value_json.ExchangeRate.Country|selectattr('@ID','eq','GBP')|first)['FXcashless']['@Sale'] }}"
- name: Kurz CSOB CZK USD
value_template: "{{ (value_json.ExchangeRate.Country|selectattr('@ID','eq','USD')|first)['FXcashless']['@Sale'] }}"
- name: Kurz CSOB CZK PLN
value_template: "{{ (value_json.ExchangeRate.Country|selectattr('@ID','eq','PLN')|first)['FXcashless']['@Sale'] }}"
mekaneck
(Rick)
November 2, 2023, 12:08am
4
Check that the resource actually loads. I’m getting an error when visiting https://csob.cz/spa/exrate/exrates/-/date/2023-11-01/kurzovni-listek.xml
YES, that was in princip correct!
I hade to remove the -/date/ and it´s working fine!
