I, indeed, want to be able to control that appliance from my home assistant installation but I just cannot figure out what I need. Every RF research I have done leads me back to 433Mhz frequency and the sonoff RF bridge which, from my understanding, does not support 315Mhz.
Looks like I am going to need to setup OpenMQTTGateway but what hardware should I be using to learn, send and receive 315Mhz RF signals with Home assistant?
I am using Home assistant 0.99.2 on hass.io, installed on a mac-mini i7 with Ubuntu 18.04.3 LTS. I already have my z-wave and zigbee bridges up and running.
I did… and I am still confused
Good point about asking on the OpenMQTT forum. Will do that now.
I was just thinking someone else must have already done that with his home assistant… I can’t be the 1st one.
Broadlink RM Pro+ ordered !
It’s not obvious from the product description that 315MHz is supported, but looks like this is actually the case.
Thank you for the info!
I am able to turn on and off my fireplace with that device. I used nodered to “learn” the codes from the remote.
I did not spend more time on it, I don’t know yet if I can catch the signal sent from the remote to the fireplace and automatically update a sensor (fireplace ON/OFF) automatically so the sensor always knows the status of the fireplace even if it’s turned on by the remote (not homeassistant).
There is most probably a more reliable way to do the same with an ESP but I did not dig into that.
I ordered the RM PRO+ and like yoou i have the exact same remote. I could not teach it any RF commands which seems like an on going issue in the forums.
I am pulling out my hair trying to get this working.
Any chance you can share your learnt remote commands here?
Hi, sorry for open thread after one year, but i’v searching 315mhz bridge nowadays and i found upgraded Sonoff RF Bridge Long Range https://www.joom.com/en/products/5caaf2fe36b54d0101c5c152
(i’v read that is sucesor of old Sonof 433mhz bridge that its flashable with tasmota). I was searching in many places and could not found anything about working it with HA or even possibility to flash tasmota firmware like this old one. It is fresh new devices that i cannot found anything about it? or it would not work with HA yet? Somebody have that one to play with or test with or without HA? I think that it could be great alternative to Broadlink you’ve mentioned in thread.
I don’t think this device is related to SONOFF, I used to have one but I don’t have it anymore. I can confirm it is an ESP into it but the decoding part seems to be done by a nuvoton uC.
Finally i bought Broadlink 4 RM Pro and it has 433, 315 mhz and irda (and even temp and humidity sensor in some aliexpress wersions). Broadlink write about working 315 mhz in rm4 pro on their site only, all aliexpress rm4 pro has both frequency… They do new app for it which is working great as an app, but when trying decode 315 mhz codes for HA purpose I had some issiues. But 435 and irda with HA works like a charm. Posting it for this who is lurking for 315mhz.
Now I’m intrigued. I always thought the broadlink RM Pro was a send-only devices, and you had to do a lot of workarounds to get it to catch codes. So you can just a button on a rf remote and it gets transmitted to HA for processing, without first having to use broadlink.learn etc ?
