Hi, i want to share this simple 2MQTT script.
It’s based on a mir:ror usb device from Violet company (creator of nabaz:tag and karotz)
It just parse mir:ror status and rfid tag directly to a mqtt broker.
I don’t think it needs an integration if someone really wants i could have a look but in my case it’s used on a remote pi and nuc, not on the HASS machine.
I’m digging up this topic …
I am in the process of transferring my environment from Jeedom to Home Assistant and one of the things my daughters asked ( requested ) is that this mir:ror continues to work … It is used as a game/fun to run scenarios.
I’m not advanced enough to integrate your development into Home Assistant myself. Is it possible to have some exchanges on this ? My goal is to connect it to a remote RPI (or NUC) and then to HA.
I also saw that you did some development for the Karotz, I’m also interested in that: same goal, moving to Home Assistant while keeping the fun parts…
It’s a simple python script all you need to do is to make it auto start on boot .
And little configuration for last IP at least.
I didn’t touch it sinc this post so do not remember so much.
For the karate, mine got wifi issue so I didn’t use it anymore. I remember they’re is a packages on GitHub to use it as is directly (all in one yaml files).
Do hesitate to ask here I’ll try to help as I can.
