I am on version 2022.7.2. running Synology docker. Now my devices using the RFLink integration do not respond anymore.
I allways keep the previous versions, and it still works with version 2022.5.4.
I did not install 2022.6.x
Anyone else facing this problem, and has a solution ? My synology version is DSM 6
In a previous topic I started I assumed the cause of this problem was a wrong usb path, but testing previous versions prove that the rflink setting are correct.
