Hi javicalle,
Thanks and sorry, my last email was confusing and i will remove it (i actually saw an UP command in the log for the first time got excited but i did not check if the cover: RTS_Sunsensor_cover caught the event).
My configuration.yaml looks like below (although i do have some more covers not showed here)
cover:
- platform: rflink
devices:
rts_14ccca0_01:
fire_event: true
In the logger see the below for DOWN that the cover: RTS_Sunsensor_cover catches
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] received data: 20;7C;Debug;RTS P1;a0e400024ccca0;
20;7D;RTS;ID=14ccca0;SWITCH=01;CMD=DOWN;
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] got packet: 20;7C;Debug;RTS P1;a0e400024ccca0;
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'debug', 'rts_p1': 'a0e400024ccca0'}
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'raw', 'value': None, 'tm': None, 'pulses': None}
2021-08-17 18:36:10 DEBUG (MainThread) [homeassistant.components.rflink] event of type unknown: {'id': 'raw', 'value': None, 'tm': None, 'pulses': None}
2021-08-17 18:36:10 DEBUG (MainThread) [homeassistant.components.rflink] unhandled event of type: unknown
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] got packet: 20;7D;RTS;ID=14ccca0;SWITCH=01;CMD=DOWN;
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'rts', 'id': '14ccca0', 'switch': '01', 'command': 'down'}
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'rts_14ccca0_01', 'command': 'down'}
2021-08-17 18:36:10 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'rts_14ccca0_01', 'command': 'down'}
2021-08-17 18:36:10 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['cover.rts_sunsensor_cover']
2021-08-17 18:36:10 DEBUG (MainThread) [homeassistant.components.rflink] passing event to cover.rts_sunsensor_cover
2021-08-17 18:36:10 DEBUG (MainThread) [homeassistant.components.rflink] Fired bus event for cover.rts_sunsensor_cover: down
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] received data: 20;7E;Debug;RTS P1;a0e4
2021-08-17 18:36:10 DEBUG (MainThread) [rflink.protocol] received data: 00024ccca0;
…and the below for STOP that the cover: RTS_Sunsensor_cover do not catches
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] received data: 20;4E;Debug;RTS P1;a0e600004cc
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] received data: ca0;
20;4F;RTS;ID=14ccca0;SWITCH=01;CMD=STOP;
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] got packet: 20;4E;Debug;RTS P1;a0e600004ccca0;
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'debug', 'rts_p1': 'a0e600004ccca0'}
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'raw', 'value': None, 'tm': None, 'pulses': None}
2021-08-17 18:19:31 DEBUG (MainThread) [homeassistant.components.rflink] event of type unknown: {'id': 'raw', 'value': None, 'tm': None, 'pulses': None}
2021-08-17 18:19:31 DEBUG (MainThread) [homeassistant.components.rflink] unhandled event of type: unknown
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] got packet: 20;4F;RTS;ID=14ccca0;SWITCH=01;CMD=STOP;
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'rts', 'id': '14ccca0', 'switch': '01', 'command': 'stop'}
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] got event: {'id': 'rts_14ccca0_01', 'command': 'stop'}
2021-08-17 18:19:31 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'rts_14ccca0_01', 'command': 'stop'}
2021-08-17 18:19:31 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: ['cover.rts_sunsensor_cover']
2021-08-17 18:19:31 DEBUG (MainThread) [homeassistant.components.rflink] passing event to cover.rts_sunsensor_cover
2021-08-17 18:19:31 DEBUG (MainThread) [homeassistant.components.rflink] Fired bus event for cover.rts_sunsensor_cover: stop
2021-08-17 18:19:31 DEBUG (MainThread) [rflink.protocol] received data: 20;50;Debug;RTS P1;a0e600004ccca0;
20;51;RTS;ID=14ccca0;SWITCH=01;CMD=STOP;
…i will see if i can get the traces from the event handler in the HA developer tools as well.
