I use RFLink with my Somfy RTS shutters and I can successfully control them with it.
I use the RFLink Cover integration and the Cover Time Based script/entity for RF devices.
(I also used the great description at https://github.com/filipmaelbrancke/ha-rflink-rts)
My actual configuration if someone is interested in:
rflink:
port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0000_00000000000000000000-if00
wait_for_ack: false
ignore_devices:
- rts_0c0c0c0_01
cover:
- platform: rflink
devices:
# Rfloader created remote control which is used by Home Assistant
RTS_0A0A01_0:
name: Shutter 1 RF
aliases:
- rts_0b0b01_01 # ID of the remote control (Somfy smove in this case)
type: standard # inverted
- platform: cover_rf_time_based
devices:
my_room_cover_time_based:
travelling_time_up: 28
travelling_time_down: 27
cover_entity_id: cover.shutter_1_rf
send_stop_at_ends: false #optional
always_confident: false #optional
device_class: shutter #optional
availability_template: "{{ not (is_state('cover.shutter_1_rf', 'unavailable') or is_state('cover.shutter_1_rf', 'unknown')) }}" #optional
However, I have the following questions:
1. What exactly does the parameter ignore_devices
I can’t see any difference when I add a device or not.
(There are also other devices in my neighborhood, which are then detected. But they show up in the debug log no matter if I ignore them or not).
2. Why do commands sometimes take longer?
In the example below, the command is executed after 3 seconds:
2023-01-27 14:41:10.266 DEBUG (MainThread) [homeassistant.components.rflink] Sending command: STOP to Rflink device: RTS_0A0A01_0
2023-01-27 14:41:10.267 DEBUG (MainThread) [rflink.protocol] sending command: {'protocol': 'RTS', 'id': '0A0A01', 'switch': '0', 'command': 'STOP'}
2023-01-27 14:41:10.267 DEBUG (MainThread) [rflink.protocol] writing data: '10;RTS;0A0A01;0;STOP;\r\n'
2023-01-27 14:41:13.524 DEBUG (MainThread) [rflink.protocol] received data: 20;E2;OK;
2023-01-27 14:41:13.524 DEBUG (MainThread) [rflink.protocol] got packet: 20;E2;OK;
I would expect this from a device that is connected via WLAN etc., but not one that is wired directly via USB.
3. Why is only the open and close state logged in the device (cover) log, but not stop?
This is probably a general question that has nothing to do with RFLink, but I would be interested to know.
4. Why doesn’t the Cover Time Based entity
update when changes are made with the RFLink cover?
It looks like the Cover Time Based entity
is only one way (writing). If the cover of the RFLink changes the state, the Cover Time Based entity
does not recognize it. (Neither when I operate the RFLink cover in HA, nor when the shutter is operated via a remote which is entered in the aliases of the RFLink configuration).
I know that there is the possibility to manually communicate this back to the Cover Time Based entity
, but surely this should only be necessary for a script and not for an entity?
5. What is the best way to simulate the “My” (Stop) command of Somfy RTS?
When the shutter is stopped and you press the My/Stop button, the shutter moves to a stored position. Unfortunately the state becomes wrong by this command. Are there any solutions to this problem?
Thanks in advance.
