I don’t think you can to that. If you override the value of the sensor in HA the information won’t be stent back to the stove.
You can use the entity (number.“stove name”_heating_prower) to control the heat output of the stove. I would use automations or a template to adjust the heating power based on a sensor value. I think a PID controller is the best way to do it (but not the simplest).
Ok, I think this helps me to progress.
Thank you
I ended up the the generic_thermostat example by Edi: https://edistechlab.com/ein-thermostat-in-home-assistant-erstellen/?v=3a52f3c22ed6.
This is working perfectly for my purposes.
Thanks everyone for your replies.
is anyone else struggling with very slow reaction of the API? the firenet website also takes a few seconds to change temperature, but in HA it won‘t even change sometimes
i got an automation running to turn the stove to 18 degrees in the evening. it happened a few times now, that the automation was running, but the stove was at 21 degrees the whole night.
id be the other way around
HA is way faster than there page even tho its probably being done in the same manner
Yes, I do also have similar issues. Thinking it was a wifi issue, I moved the access point closer and in line of sight bow to no avail. Sometimes I set the temperature and after 30s it goes back without user intervention. In my automation, after 1 min I to a check. And if the change was reverted I send the command again. Brute force but it work’s
Hi there friends. I’m new in HA and I found this Integration for a Rika DOMO Stove.
well done - thanks
But now my Question: Where can I get the plug-in from @Mystere
Its exactly that what I’m looking for?
Many thanks and Greetings from Niederösterreich (Austria)
Helmut
Hi Helmi55,
You need to install the Home Assistant Community Store (HACS).
This tutorial is mostly up to date
When the install is complete, install it from HACS and add the integration from the normal integration panel in HA.
Many thanks ans sorry for late answer
is there anyway to know if the pellets have run out ? … from my end in HA everything appears as working… but within firenet it will return an error when pellets have run out
I m new to homeassistant. Does anybody speak french and could help me to install rika firenet plugin to HA ? Thanks a lot and happy new year to all.
Bonsoir j’ai un poêle Rika Domo connecté a mon instance home assistant. L’intégration fonctionne bien pour surveiller le poêle, mais pour le contrôle c’est perfectible.
EN version
I have a Rika Domo stove connected to my home assistant. The integration works well for monitoring the stove, but not so well for controlling it.
im also using a Domo … which ive setup with node-red and this repository on "comfort mode’ which works really well … the only down side to this repository is there know return error if you run out of pellets
Hello, i have installed home assistant in proxmox. I have access to HA> but i would like to install the rika plugin. When i m in HA>, where i have to go to copy the rika plugin files ?
Thank you
Thank you. Got it working.
