Can confirm it’s working.
Zoneminder camera on top
Ring doorbell camera on bottom
The playback was slow, I assume that is due to ffmpeg re-encoding the video on a Pi3.
Does this only work with the cloud subscription?
I’d have to say yes due to the fact it’s pulling the URL for the video from Ring’s website
Can’t wait to try this tonight!!
I relocated the file in configuration folder under custom_components camera and nothing popped up in UI.
Am I doing something wrong as it said something about no platform. At work right now don’t have exact error
If you are using groups, you will have to add camera.ring
(or whatever the entity name is) to one of the groups.
For my AIO install I’ve placed ring.py
in /home/homeassistant/.homeassistant/custom_components/camera/
Then from the <> menu I found camera.front_door_2
as I already had camera.front_door
from Zoneminder, and added it to my groups.yaml
Hope this helps.
Already set as a group, still same error
Looking at config errors, does this make sense.
File “/home/drive/.homeassistant/custom_components/camera/ring.py”, line 10, in import dateutil.parser ImportError: No module named ‘dateutil’
Try manually installing it inside the venv pip install python-dateutil
This bit in configuration.yaml is missing it sounds like:
I’m getting the following error. Added everything per instructions above:
The following errors have been logged this session:
2017-10-05 23:52:36 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.ring. Make sure all dependencies are installed
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/loader.py", line 142, in get_component
module = importlib.import_module(path)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 986, in _gcd_import
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 665, in exec_module
File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/ring.py", line 13, in <module>
from requests.exceptions import HTTPError, ConnectTimeout
ImportError: cannot import name 'ConnectTimeout'
2017-10-05 23:52:36 ERROR (MainThread) [homeassistant.loader] Unable to find component ring
2017-10-05 23:52:36 ERROR (MainThread) [homeassistant.setup] Setup failed for ring: Component not found.
So my ring compoent loads ok, with the exception that when I call a restart within the developer area of HA it won’t restart, has the error posted above.
My second problem is, my front door camera says “Image Not Available”
And I do see this in the logs:
Any ideas??
2017-10-06 00:47:19 ERROR (MainThread) [haffmpeg.core] FFmpeg fails [Errno 2] No such file or directory: 'ffmpeg'
File "/Users/mediacenter/.homeassistant/deps/lib/python/site-packages/haffmpeg/core.py", line 114, in open
stderr=stderr
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/subprocess.py", line 212, in create_subprocess_exec
stderr=stderr, **kwds)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/base_events.py", line 1079, in subprocess_exec
bufsize, **kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/unix_events.py", line 184, in _make_subprocess_transport
**kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/base_subprocess.py", line 40, in __init__
stderr=stderr, bufsize=bufsize, **kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/unix_events.py", line 649, in _start
universal_newlines=False, bufsize=bufsize, **kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/subprocess.py", line 947, in __init__
restore_signals, start_new_session)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/subprocess.py", line 1551, in _execute_child
raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: 'ffmpeg'
2017-10-06 00:47:19 ERROR (MainThread) [aiohttp.server] Error handling request
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 422, in start
resp = yield from self._request_handler(request)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/aiohttp/web.py", line 306, in _handle
resp = yield from handler(request)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/coroutines.py", line 209, in coro
res = yield from res
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 58, in ban_middleware_handler
return (yield from handler(request))
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/http/__init__.py", line 428, in handle
result = yield from result
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/camera/__init__.py", line 340, in get
response = yield from self.handle(request, camera)
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/camera/__init__.py", line 360, in handle
image = yield from camera.async_camera_image()
File "/Users/mediacenter/.homeassistant/custom_components/camera/ring.py", line 77, in async_camera_image
extra_cmd=self._ffmpeg_arguments)
File "/Users/mediacenter/.homeassistant/deps/lib/python/site-packages/haffmpeg/tools.py", line 82, in get_image
self._proc.communicate(), loop=self._loop)
AttributeError: 'NoneType' object has no attribute 'communicate'
Figured it all out. So I had 2 problems. First I needed to update requests and found out there were 2 directories and versions of it. Got rid of the old one.
Next, I realized that I didn’t have ffmpeg installed on my mac as you noticed. Just ran brew install ffmpeg and everything is now working perfectly! Thanks so much
Awesome @Jer78
Good to hear that is working fine for you. The code still needs some polishing, but we should have a PR soon and maybe officially introduced on 0.56 version in 2 weeks.
Now the cherry’s cake now is to find a good ffmpeg
parameters to adjust the video speed when it’s playing.
Please if anyone come up with a good combination, please let me know.
Thanks everyone that tested it.
Sure did, works like a champ.
The video speed for me is perfect. No issues. But I am using a Mac Mini so I’m sure that’s giving it extra juice than a Pi. So far so good. Thanks again for adding the cam feature!
I will give it a shot again tonight.
