Ring Keypad V2: Multi-Code Routine Hub (Z-Wave)
This automation blueprint allows you to turn your Ring Keypad V2 into a fully customizable routine hub in Home Assistant, operating completely independently of Alarmo. Map single-digit keys (0–9) and one custom multi-digit PIN code to separate Home Assistant action sequences. Pressing a shortcut followed by the Checkmark button executes your custom actions with optional global audio feedback chimes.
Features
- Multi-Code Routine Hub: Map up to 10 single-digit shortcuts plus a custom multi-digit PIN to independent Home Assistant actions (scripts, scenes, automations, or device controls).
- Checkmark Triggering: Securely evaluates user input on submission via the Entry Control Command Class (CC 111).
- Global Audio Feedback: Features a customizable volume percentage slider (0%–100%) and a sound selection for confirmation chimes (Double Beep, Keytone Click, Wind Chime, Soft Error Beep) powered by Z-Wave JS Indicator Command Class (CC 135).
- Clean UI Layout: Designed with collapsible sections for every key and global setting to minimize visual clutter in the automation configuration UI.
- Independent Operation: Runs smoothly as a standalone routine manager without interfering with your native alarm panel integration.
Prerequisites
- Z-Wave JS Integration: Your Home Assistant instance must have the official
zwave_jsintegration running. - Connected Ring Keypad v2: The keypad must already be paired to your Z-Wave network.
- Note: Ring Keypads require S2 Security during pairing to process Z-Wave Indicator Command Class (135) audio feedback commands properly.
Input Reference
| Input | Type | Description |
| Ring Keypad Device | Device Selector | Select your target Ring Keypad device (automatically targets its Z-Wave entity). |
| Global Audio Options | Collapsible Section | Configure master confirmation chime volume (0%–100%) and sound effect selection. |
| Custom / Multi-Digit PIN | Collapsible Section | Define a multi-digit code (e.g., 1234), audio toggle, and associated action. |
| Key 0 – 9 Actions | Collapsible Sections | Define specific Home Assistant action sequences and individual audio toggles for each single-digit shortcut (triggered via Key + Checkmark). |
Pro Tips
- Keep it Documented: Pair this blueprint with a simple text helper and a dashboard Markdown card to maintain a living cheat sheet of your assigned button shortcuts for family or guests.
- Audio Feedback: Enable confirmation chimes selectively on high-impact routines (like opening a garage door) while keeping quiet shortcuts silent.
- Z-Wave JS Health: Ensure your Ring Keypad has a direct or strong Z-Wave mesh connection to guarantee instant event responses.
Acknowledgments & Credits
Special thanks to these Home Assistant community members for their invaluable research and contributions to Ring Keypad v2 integrations:
- @ImSorryButWho – Creator of the original Ring Keypad Automations blueprint, establishing early standards for pairing and synchronizing keypads with Home Assistant.
- @NobleWolf – Creator of the Ring Keypad v2 Sounds SCRIPT, zwaveJS work, providing initial technical insights into mapping Z-Wave Indicator Command Class (CC 135) audio commands.
Installation
Method 1: Click to Import (Easiest)
Click the badge below to import this blueprint directly into your Home Assistant instance:
Method 2: Manual Installation
- Download or clone the raw
ring_keypad_routine.yamlfile from this repository.ring_keypad_routine.yaml - In your Home Assistant configuration directory, navigate to your blueprints folder (e.g.,
config/blueprints/automation/ufans123/home-assistant-blueprints/). - Paste the code into a file named
ring_keypad_routine.yaml. - Reload your automations or restart Home Assistant.
Method 3: Manual Installation using the Blueprints Dashboard (Easiest)
- Copy the following URL:
https://github.com/ufans123/home-assistant-blueprints/blob/main/ring_keypad_routine.yaml
- Navigate to your Home Assistant Blueprints Dashboard UI (Settings > Automations & Scenes > Blueprints).
- In the bottom right corner, click on the ‘Import blueprint’ button.
- Paste in the URL and follow the prompts.
