Rinnai/Brivis have finally released their wifi module and app found here
I have no coding knowledge but would love to help in any way to create a component. This is possibly only relevant for Australian users.
UPDATE: After amazing work by many, @Mantorok has developed a Homebridge plugin here
UPDATE 2: Thanks to many inclduing @funtastix we now have a HACS Home Assistant intergration here
@mitchmario I assume no one knows about this yet. I only found out about this existing by seeing your post. Might go buy one, unfortunately I don’t have the know-how to create a component.
I will. I am picking it up today, so once I confirm it is the correct item I will share. I don’t want to inundate them with orders and then it turns out to be the wrong item, that would be painful for everyone.
Installing was easy. I have a nc6 controller. No cables supplied with that one. Just got a speaker cable and used that to wire it. Wouldn’t connect to my pixel3 phone, used an iPad to set it up.
Short of that. All up and going in 30 minutes.
Excellent. I will order one and as soon as I get it I will try and capture the API calls from the app with something like Android Snopper. Then I believe it is a matter of taking those calls and creating a climate component, probably by taking and editing a similar climate component. Can you tell if it can operate without internet? As in local connection only
So I just discovered it has a web gui.
Once installed you can browse to the IP and it will bring up a web gui called “mysimplelink”
It uses the mysimplelink.net webgui, which if you google you will see a heap of devices use it. So i am hopeful this means we might get somewhere with this.
Awesome that will help a lot I imagine. Instead of snooping an app I can snoop the web gui with a chrome add on like this. If you have time, see if anything interesting comes up. Lets say when you adjust the temp you see a GET or POST request, you can copy that request url and create a command in Home Assistant with the Rest Component
Thanks for the contact. They had one left and the price went up from $255 to $295 between holds. Still a good price but I couldn’t meet their hold conditions.
I’m picking up mine this week from Alder Heating and Air Conditioning
Pakenham VIC for $275. Was the cheapest I found out of 20 places in the South East.
