@knackers24 I’ve just installed mine and got it working with the app. But the mysimplelink web gui doesn’t seem to offer any thermostat control. Is this what you have found?
yeah, it is just a network gui.
For those living in the inner western suburbs of Melbourne, I ended up getting mine for $276 at Advance Heating and Cooling in Braybrook.
Ok so with my little knowledge Wireshark and packet sniffing I’ve found that it’s not sending over http, but plain old TCP. This is what my iOS app sends to set the thermostat to 12 degrees -
{"HGOM": {"ZAO": {"SP": "12" } } }
and then the thermostat responds with this. I’ve bolded what I can understand - the time, date and current and goal temperatures for my 2 zones. Next step is finding someone who knows what they’re doing lol
EiÀ¨À¨lÇÅï8N>ÄP,IN000010[{“SYST”: {“CFG”: {“MTSP”: “Y”, “NC”: “00”, “DF”: “N”, “TU”: “C”, “CF”: “1”, “VR”: “0183”, “CV”: “0010”, “CC”: “043”, “ZA”: " ", “ZB”: " ", “ZC”: " ", “ZD”: " " }, “AVM”: {“HG”: “Y”, “EC”: “N”, “CG”: “Y”, “RA”: “N”, “RH”: “N”, “RC”: “N” }, “OSS”: {“DY”: “THU”, “TM”: “11:59”, “BP”: “Y”, “RG”: “Y”, “ST”: “N”, “MD”: “H”, “DE”: “N”, “DU”: “N”, “AT”: “999”, “LO”: “N” }, “FLT”: {“AV”: “N”, “C3”: “000” } } },{“HGOM”: {“CFG”: {“ZUIS”: “N”, “ZAIS”: “Y”, “ZBIS”: “Y”, “ZCIS”: “N”, “ZDIS”: “N”, “CF”: “N”, “PS”: “Y”, “DG”: “W” }, “OOP”: {“ST”: “N”, “CF”: “N”, “FL”: “00”, “SN”: “Y” }, “ZUO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZAO”: {“OP”: “M”, “SP”: “12”, “AO”: “N” }, “ZBO”: {“OP”: “M”, “SP”: “19”, “AO”: “N” }, “ZCO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZDO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZUS”: {“AE”: “N”, “MT”: “243”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZAS”: {“AE”: “N”, “MT”: “226”, “ID”: “Y”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “L”, “AZ”: “L” }, “ZBS”: {“AE”: “N”, "MT": “243”, “ID”: “Y”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZCS”: {“AE”: “N”, “MT”: “243”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZDS”: {“AE”: “N”, “MT”: “243”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “APZ”: {“ZV”: “N” } } }]
EDIT: Here is the documentation for mysimplelink, it has some details on their implementation of the TCP/UDP protocol.
EDIT 2: According to this breakdown of a prototype mysimplelink device, the iOS and Android apps are communicating with the RESTful API.
so apparently Google Assistant is coming to this device sometime later this year. At least that is something…
Yep a rep told me that also. HomeKit is what we really need to get this into Hass
Turns out that payload is MQTT. I have decompiled the app and found the different payloads for each MQTT command. There is a lot
Sorry mate, I can’t help ya with this. I am a hardware guy, not a software guy.
No worries, I’m stuck too unfortunately. I have made a post asking for some some tips on decrypting the MQTT credentials. Hopefully we get some answers!
I purchased one of these units (should’ve checked here first for better prices). I configured it easily first time and it was working a charm. I had to unplug it to relocate and haven’t been able to reconfigure it again. I get to the “save settings” screen on my iPhone and when I hit “next” it defaults back to the initial configure screen. I have the unit in the default APS mode. I’ve uninstalled/reinstalled the app, rebooted my router and reset the Rinnai wifi module, all to no avail. Any other tips please? I’ve contacted Rinnai and waiting to hear back.
Got another phone in the household? or next door neighbor?, see if you can get it set up and registered on their phone and then try to connect yours after connected.
I couldn’t get it connected on my phone, so I used an ipad to set it up and then added it to my phone once setup.
Thanks knackers24. I used my iPad and it worked a treat. The conenction between the Rinnai device and the router ‘broke’ a couple of times so I moved the router closer. You’ve saved me a lot of frustration. Helpful people on helful forums like this are great. Thanks again.
happy to help mate. Glad you got it going.
I too have bought this wifi module and am trying to reverse engineer the API to integrate into a home automation controller. I’ve captured the same packet data as you between my iOS device and the wifi unit.
It appears as though this is not MQTT - MQTT is a binary wire protocol and the packet capture clearly shows a JSON payload.
Googling some of the keys like “SYST” and “HGOM” yields no meaningful results. I’m starting to think this is some kind of custom/proprietary API.
You are right though, you can work out some of the important items by eyeballing the data, e.g.
SYST = system
CFG = config
TU = temperature unit
VR = version
CV = module wifi version (this is shown in the app)
DY = day
TM = time
ZA … ZD = zone a … zone d
{“HGOM”: {“CFG”: {“ZUIS”: “N”, “ZAIS”: “Y”, “ZBIS”: “Y”, “ZCIS”: “N”, “ZDIS”: “N”, “CF”: “N”, “PS”: “Y”, “DG”: “W” } - this part tell you which zones you have - e.g. A and B are “Y” the rest are “N”
ZAO = zone A operation? (same for zone b, c and d - no idea what zone u is, perhaps universal?)
OP = operation (i assume “m” = manual)
SP = set point (set temp)
ZAS = sone A status ? (same for zone b, c and d - no idea what zone u is, perhaps universal?)
MT = measured temp (e.g. 226 = 22.6C?)
I don’t think much of the rest really matters - these are status packets that are sent regularly… you just need to pull out the bits you are interested in and display/use those and ignore the rest.
As for setting the temp, that message was simple:
{“HGOM”: {“ZAO”: {“SP”: “12” } } }
HGOM = no idea
There are really only a few commands that need to be figured out. On/off, set temp. I also have evap cooling so need to figure out how to switch modes and control that too!
Another observation is that all the JSON messages are prepended with a string - in your case “N000010”. In my case N000045 then N000046 - maybe some sort of incrementing message counter?
I’m also wondering how to establish a connection to this device… the port numbers seem somewhat random which suggests there is some sort of negotiation that occurs first (between the app and the cloud?) before the app connects directly to the device.
I’ll keep poking around and see what i find.
/JB
Having said that, both yours and mine connected on TCP port 27847.
Brilliant I’m excited someone else is looking into this. You’re right if we could connect to the module it would not be hard to send the right messages. I had a look through the Android app again and I think HGOM means Heating Operation Mode, as there is also CGOM for Cooling. Here’s two files I extracted from the API.dll CHeating CCooling
Interesting find about MQTT, inside the Android app there are many libraries related to some sort of MQTT implementation, mostly labled CMQTT. I think it’s CloudMQTT possibly used to communicate through the internet. I also discovered a more recent feature of MQTT is communication over the Websockets protocol, which doesn’t use standard ports. It may also have TLS encryption. I found others online trying to decode TLS and it looked similar to what I was seeing in Wireshark - data starting with an encoded packet followed by a readable payload. I think that encoded packet may include the credentials and topic.
If it is MQTT or something else, I think there is a private key in the module, and public keys in the app. The only way I can imagine extracting the private key is if Brivis releases a firmware file, or if I can access a serial debug output from the module’s CC3220 board. I opened up the module (easily, its just 4 clips) but Brivis have created a custom board with no TX and RX labelled pins like the standard board has. My next step was to buy an oscilloscope and find the pins, but I can’t justify the cost. Anyway I’ll attach some screenshots of the MQTT and TLS references I found in DotPeek.
MQTT Screenshot 1
MQTT Screenshot 2
TLS Screenshot
If anyone else wants too look around
Rinnai Touch Android APK
How to Decompile
DotPeek
Nice work!
I think all the info we need to interact with the API locally is there. It appears that all of the MQTT/TLS code is required for remote, cloud access. Accessing the API from the local LAN appears to be a simple TCP-based protocol, defined in CWIFIAccess.cs - can you post that entire file somewhere?
Local LAN discovery involves listening for UDP packets on port 50000 and looking for a packet starting with the string “Rinnai_NBW2_Module”. The wifi module broadcasts these UDP packets to the local LAN once per second by the looks of it. This is a dump of it’s contents:
0000 52 69 6e 6e 61 69 5f 4e 42 57 32 5f 4d 6f 64 75 Rinnai_NBW2_Modu
0010 6c 65 00 00 00 00 00 00 00 00 00 00 00 00 00 00 le…
0020 6c c7 55 b7 0a 02 00 00 00 00 00 00 00 00 00 00 l.U…
0030 34 48 52 46 4d 56 33 52 30 56 00 00 00 00 00 00 4HRFMV3R0V…
0040 c7 bb 1d 1d 10 72 af b1 20 59 8d b7 37 a8 d3 65 …r… Y…7…e
0050 1a cf 85 71 ab 14 a8 98 4f c7 c4 35 a5 fe 84 64 …q…O…5…d
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00a0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00b0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00c0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00d0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00e0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
00f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …
The first 2 bytes of location 0020 (6c c7) equals 27847 which is the TCP port used to connect to the module. I’m sure the other data is used for something as well (authentication perhaps?). These UDP broadcasts tell us everything we need to know in order to connect to the API over TCP - most of which should be defined in your CWIFIAccess.cs file.
I’ll play around with it a little more later tonight when I have some time.
This is excellent news. Here is the CWIFIAccess.cs
I’ve noticed it contains the ‘HELLO’ message that I see in wireshark, but I don’t understand much else in there unfortunately. I see that it may be using some sort of authentication
this.DeviceDefaultPassord = Encoding.UTF8.GetString(e.RxPacket.Buffer, 48, 10);
public string DeviceDefaultPassord { get; private set; }
Where this password is I don’t know.
EDIT: These also seem related to the local connection CNetworker.cs CNBWControl.cs
@J_B Do you have any more thoughts about this TCP communication?
I might try this when I have the chance -
