Ok, I think i’ve captured all that.
Here is the Status when Brivis & All 4 zones have been turned on via Touch App
Zone A set to = 26, Zone B set to = 25, Zone C set to= 23, Zone D set to = 22
[6/14/2021, 6:16:33 PM] [Brivis] [{“SYST”: {“CFG”: {“MTSP”: “Y”, “NC”: “07”, “DF”: “N”, “TU”: “C”, “CF”: “1”, “VR”: “0183”, “CV”: “0010”, “CC”: “043”, “ZA”: "Main Living ", “ZB”: "Theatre ", “ZC”: "Master Bedroom ", “ZD”: "Rear Bedrooms " }, “AVM”: {“HG”: “Y”, “EC”: “N”, “CG”: “Y”, “RA”: “N”, “RH”: “N”, “RC”: “N” }, “OSS”: {“DY”: “MON”, “TM”: “18:16”, “BP”: “Y”, “RG”: “Y”, “ST”: “N”, “MD”: “H”, “DE”: “N”, “DU”: “N”, “AT”: “999”, “LO”: “N” }, “FLT”: {“AV”: “N”, “C3”: “000” } } },{“HGOM”: {“CFG”: {“ZUIS”: “N”, “ZAIS”: “Y”, “ZBIS”: “Y”, “ZCIS”: “Y”, “ZDIS”: “Y”, “CF”: “N”, “PS”: “N”, “DG”: “W” }, “OOP”: {“ST”: “N”, “CF”: “N”, “FL”: “07”, “SN”: “N” }, “ZUO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZAO”: {“OP”: “M”, “SP”: “26”, “AO”: “N” }, “ZBO”: {“OP”: “M”, “SP”: “25”, “AO”: “N” }, “ZCO”: {“OP”: “M”, “SP”: “23”, “AO”: “N” }, “ZDO”: {“OP”: “M”, “SP”: “22”, “AO”: “N” }, “ZUS”: {“AE”: “N”, “MT”: “235”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZAS”: {“AE”: “Y”, “MT”: “235”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZBS”: {“AE”: “Y”, “MT”: “213”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZCS”: {“AE”: “Y”, “MT”: “214”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZDS”: {“AE”: “N”, “MT”: “210”, “ID”: “Y”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “APZ”: {“ZV”: “N” } } }]
[6/14/2021, 6:16:33 PM] [homebridge-rinnai-touch-platform] This plugin generated a warning from the characteristic ‘Cooling Threshold Temperature’: characteristic was supplied illegal value: number 0 exceeded minimum of 8. See Characteristic Warnings · homebridge/homebridge Wiki · GitHub for more info.
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/hvac/action/get, Payload: {“A”:“off”,“B”:“off”,“C”:“off”,“D”:“off”}
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/hvac/current_temperature/get, Payload: {“A”:23.5,“B”:21.3,“C”:21.4,“D”:21}
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/hvac/fan_mode/get, Payload: medium
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/hvac/mode/get, Payload: heat
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/hvac/temperature/get, Payload: {“A”:26,“B”:25,“C”:23,“D”:22}
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/zone/a/get, Payload: off
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/zone/b/get, Payload: off
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/zone/c/get, Payload: off
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/zone/d/get, Payload: off
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/heat/get, Payload: on
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/cool/get, Payload: off
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/evap/get, Payload: off
[6/14/2021, 6:16:33 PM] [Brivis] MQTT: Publish: brivis/switch/fan/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] [{“SYST”: {“CFG”: {“MTSP”: “Y”, “NC”: “07”, “DF”: “N”, “TU”: “C”, “CF”: “1”, “VR”: “0183”, “CV”: “0010”, “CC”: “043”, “ZA”: "Main Living ", “ZB”: "Theatre ", “ZC”: "Master Bedroom ", “ZD”: "Rear Bedrooms " }, “AVM”: {“HG”: “Y”, “EC”: “N”, “CG”: “Y”, “RA”: “N”, “RH”: “N”, “RC”: “N” }, “OSS”: {“DY”: “MON”, “TM”: “18:16”, “BP”: “Y”, “RG”: “Y”, “ST”: “N”, “MD”: “H”, “DE”: “N”, “DU”: “N”, “AT”: “999”, “LO”: “N” }, “FLT”: {“AV”: “N”, “C3”: “000” } } },{“HGOM”: {“CFG”: {“ZUIS”: “N”, “ZAIS”: “Y”, “ZBIS”: “Y”, “ZCIS”: “Y”, “ZDIS”: “Y”, “CF”: “N”, “PS”: “N”, “DG”: “W” }, “OOP”: {“ST”: “N”, “CF”: “N”, “FL”: “07”, “SN”: “N” }, “ZUO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZAO”: {“OP”: “M”, “SP”: “26”, “AO”: “N” }, “ZBO”: {“OP”: “M”, “SP”: “25”, “AO”: “N” }, “ZCO”: {“OP”: “M”, “SP”: “23”, “AO”: “N” }, “ZDO”: {“OP”: “M”, “SP”: “22”, “AO”: “N” }, “ZUS”: {“AE”: “N”, “MT”: “235”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZAS”: {“AE”: “Y”, “MT”: “235”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZBS”: {“AE”: “Y”, “MT”: “213”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZCS”: {“AE”: “Y”, “MT”: “214”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZDS”: {“AE”: “Y”, “MT”: “210”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “APZ”: {“ZV”: “N” } } }]
[6/14/2021, 6:16:35 PM] [homebridge-rinnai-touch-platform] This plugin generated a warning from the characteristic ‘Cooling Threshold Temperature’: characteristic was supplied illegal value: number 0 exceeded minimum of 8. See Characteristic Warnings · homebridge/homebridge Wiki · GitHub for more info.
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/hvac/action/get, Payload: {“A”:“off”,“B”:“off”,“C”:“off”,“D”:“off”}
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/hvac/current_temperature/get, Payload: {“A”:23.5,“B”:21.3,“C”:21.4,“D”:21}
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/hvac/fan_mode/get, Payload: medium
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/hvac/mode/get, Payload: heat
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/hvac/temperature/get, Payload: {“A”:26,“B”:25,“C”:23,“D”:22}
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/zone/a/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/zone/b/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/zone/c/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/zone/d/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/heat/get, Payload: on
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/cool/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/evap/get, Payload: off
[6/14/2021, 6:16:35 PM] [Brivis] MQTT: Publish: brivis/switch/fan/get, Payload: off
And this is Zone B set to Off in Touch App
[6/14/2021, 6:24:55 PM] [Brivis] [{“SYST”: {“CFG”: {“MTSP”: “Y”, “NC”: “07”, “DF”: “N”, “TU”: “C”, “CF”: “1”, “VR”: “0183”, “CV”: “0010”, “CC”: “043”, “ZA”: "Main Living ", “ZB”: "Theatre ", “ZC”: "Master Bedroom ", “ZD”: "Rear Bedrooms " }, “AVM”: {“HG”: “Y”, “EC”: “N”, “CG”: “Y”, “RA”: “N”, “RH”: “N”, “RC”: “N” }, “OSS”: {“DY”: “MON”, “TM”: “18:24”, “BP”: “Y”, “RG”: “Y”, “ST”: “N”, “MD”: “H”, “DE”: “N”, “DU”: “N”, “AT”: “999”, “LO”: “N” }, “FLT”: {“AV”: “N”, “C3”: “000” } } },{“HGOM”: {“CFG”: {“ZUIS”: “N”, “ZAIS”: “Y”, “ZBIS”: “Y”, “ZCIS”: “Y”, “ZDIS”: “Y”, “CF”: “N”, “PS”: “N”, “DG”: “W” }, “OOP”: {“ST”: “N”, “CF”: “N”, “FL”: “07”, “SN”: “N” }, “ZUO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZAO”: {“OP”: “M”, “SP”: “26”, “AO”: “N” }, “ZBO”: {“OP”: “M”, “SP”: “00”, “AO”: “N” }, “ZCO”: {“OP”: “M”, “SP”: “23”, “AO”: “N” }, “ZDO”: {“OP”: “M”, “SP”: “22”, “AO”: “N” }, “ZUS”: {“AE”: “N”, “MT”: “233”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZAS”: {“AE”: “Y”, “MT”: “233”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZBS”: {“AE”: “Y”, “MT”: “213”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZCS”: {“AE”: “Y”, “MT”: “218”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZDS”: {“AE”: “Y”, “MT”: “213”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “APZ”: {“ZV”: “N” } } }]
[6/14/2021, 6:24:55 PM] [homebridge-rinnai-touch-platform] This plugin generated a warning from the characteristic ‘Heating Threshold Temperature’: characteristic was supplied illegal value: number 0 exceeded minimum of 8. See Characteristic Warnings · homebridge/homebridge Wiki · GitHub for more info.
[6/14/2021, 6:24:55 PM] [homebridge-rinnai-touch-platform] This plugin generated a warning from the characteristic ‘Cooling Threshold Temperature’: characteristic was supplied illegal value: number 0 exceeded minimum of 8. See Characteristic Warnings · homebridge/homebridge Wiki · GitHub for more info.
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/hvac/action/get, Payload: {“A”:“off”,“B”:“off”,“C”:“off”,“D”:“off”}
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/hvac/current_temperature/get, Payload: {“A”:23.3,“B”:21.3,“C”:21.8,“D”:21.3}
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/hvac/fan_mode/get, Payload: medium
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/hvac/mode/get, Payload: heat
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/hvac/temperature/get, Payload: {“A”:26,“B”:0,“C”:23,“D”:22}
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/zone/a/get, Payload: off
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/zone/b/get, Payload: off
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/zone/c/get, Payload: off
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/zone/d/get, Payload: off
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/heat/get, Payload: on
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/cool/get, Payload: off
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/evap/get, Payload: off
[6/14/2021, 6:24:55 PM] [Brivis] MQTT: Publish: brivis/switch/fan/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] [{“SYST”: {“CFG”: {“MTSP”: “Y”, “NC”: “07”, “DF”: “N”, “TU”: “C”, “CF”: “1”, “VR”: “0183”, “CV”: “0010”, “CC”: “043”, “ZA”: "Main Living ", “ZB”: "Theatre ", “ZC”: "Master Bedroom ", “ZD”: "Rear Bedrooms " }, “AVM”: {“HG”: “Y”, “EC”: “N”, “CG”: “Y”, “RA”: “N”, “RH”: “N”, “RC”: “N” }, “OSS”: {“DY”: “MON”, “TM”: “18:24”, “BP”: “Y”, “RG”: “Y”, “ST”: “N”, “MD”: “H”, “DE”: “N”, “DU”: “N”, “AT”: “999”, “LO”: “N” }, “FLT”: {“AV”: “N”, “C3”: “000” } } },{“HGOM”: {“CFG”: {“ZUIS”: “N”, “ZAIS”: “Y”, “ZBIS”: “Y”, “ZCIS”: “Y”, “ZDIS”: “Y”, “CF”: “N”, “PS”: “N”, “DG”: “W” }, “OOP”: {“ST”: “N”, “CF”: “N”, “FL”: “07”, “SN”: “N” }, “ZUO”: {“OP”: “M”, “SP”: “20”, “AO”: “N” }, “ZAO”: {“OP”: “M”, “SP”: “26”, “AO”: “N” }, “ZBO”: {“OP”: “M”, “SP”: “00”, “AO”: “N” }, “ZCO”: {“OP”: “M”, “SP”: “23”, “AO”: “N” }, “ZDO”: {“OP”: “M”, “SP”: “22”, “AO”: “N” }, “ZUS”: {“AE”: “N”, “MT”: “233”, “ID”: “N”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZAS”: {“AE”: “Y”, “MT”: “233”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZBS”: {“AE”: “N”, “MT”: “213”, “ID”: “Y”, “FS”: “N”, “GV”: “N”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZCS”: {“AE”: “Y”, “MT”: “218”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “ZDS”: {“AE”: “Y”, “MT”: “213”, “ID”: “Y”, “FS”: “Y”, “GV”: “Y”, “PH”: “N”, “AT”: “W”, “AZ”: “W” }, “APZ”: {“ZV”: “N” } } }]
[6/14/2021, 6:24:57 PM] [homebridge-rinnai-touch-platform] This plugin generated a warning from the characteristic ‘Heating Threshold Temperature’: characteristic was supplied illegal value: number 0 exceeded minimum of 8. See Characteristic Warnings · homebridge/homebridge Wiki · GitHub for more info.
[6/14/2021, 6:24:57 PM] [homebridge-rinnai-touch-platform] This plugin generated a warning from the characteristic ‘Cooling Threshold Temperature’: characteristic was supplied illegal value: number 0 exceeded minimum of 8. See Characteristic Warnings · homebridge/homebridge Wiki · GitHub for more info.
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/hvac/action/get, Payload: {“A”:“off”,“B”:“off”,“C”:“off”,“D”:“off”}
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/hvac/current_temperature/get, Payload: {“A”:23.3,“B”:21.3,“C”:21.8,“D”:21.3}
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/hvac/fan_mode/get, Payload: medium
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/hvac/mode/get, Payload: heat
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/hvac/temperature/get, Payload: {“A”:26,“B”:0,“C”:23,“D”:22}
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/zone/a/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/zone/b/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/zone/c/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/zone/d/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/heat/get, Payload: on
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/cool/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/evap/get, Payload: off
[6/14/2021, 6:24:57 PM] [Brivis] MQTT: Publish: brivis/switch/fan/get, Payload: off
Please let me know if i’ve missed anything.
Thanks once again
