Risco alarm system
Change everything and using daytime now, but without luck to sync :frowning:
Its getting worse lol, it was working before, now it says theres something wrong my json, although i didnt change a thing.
I even recopied everything to be sure, but still error
Loading config from: /config/risco-mqtt.json
Startup error SyntaxError: /config/risco-mqtt.json: Unexpected token } in JSON at position 358
at parse ()
at Object.Module._extensions…json (node:internal/modules/cjs/loader:1266:39)
at Module.load (node:internal/modules/cjs/loader:1076:32)
at Function.Module._load (node:internal/modules/cjs/loader:911:12)
at Module.require (node:internal/modules/cjs/loader:1100:19)
at require (node:internal/modules/cjs/helpers:119:18)
at Object. (/app/dist/main.js:23:24)
at Module._compile (node:internal/modules/cjs/loader:1198:14)
at Object.Module._extensions…js (node:internal/modules/cjs/loader:1252:10)
You are not using the proxy anymore?
What do you mean? Yes i am…
In the risco panel, i didnt change the ip adress from the cloud, its still pointing to my HA device
Your json needs the proxy setting, otherwise it won’t work.
“socketMode”: “proxy”,
Also there is an extra comma that shouldn’t be there on the line with the off delay, that’s causing the json error.
Yeah , but you don’t configure the addon to use the proxy, it was still a direct connection…
Earlier you posted my config and now you post a total different config?
Ohhh no i never used that
yup that fixed it.
Im gonna stop it again and add the socketmode line
Anything else?
RiscoCloud Socket: ready
Aha!
So maybe now the clock will adjust too?
If you start the addon with the proxymodz enabled, do you see the panel connecting now? You should see it in the log, it can take up to 2 minutes…
Make sure that you have cloud enabled on your panel, because it’s probably not… Otherwise you the addon in non-proxy mode should never work, and in your case it did…
Use these settings…
    "panelIp": "192.168.1.150",
    "panelPort": 1000,
    "panelPassword": XXXXX,
    "panelId": "0001",
    "watchDogInterval": 10000,
	"cloudConnectionDelay": 10000,
	"guessPasswordAndPanelId": false,
	"Disable_RiscoCloud":  true,
	"Enable_RiscoCloud":  true,
	"autoDiscover":  false,
	"socketMode": "proxy",
	"listeningPort": 33000,
	"cloudPort": 33000,
	"cloudUrl": "www.riscocloud.com"
If everything is OK, it should look like this:
No need to i think.
Everything is back up, and the clock on the panel synced now!
However i do see errors in the addon log
Ignore those warnings, they are normal! I have them too
Ok so all working well now, thanks a lot !
Finally :slight_smile:
Yeah sorry :slight_smile:
Hi, this add-on is compatible with lightsys+? thanks
Did you try it?
Hey there!
I’m trying to use the risco-mqtt-local addon for my risco panel using it locally (so no cloud!). I am however unable to connect to my panel with the following showing in the logs:
1/25/2024, 12:03:11 AM [error] Command[1] error: Error: write ECONNRESET
1/25/2024, 12:03:11 AM [error] Socket Closed.
1/25/2024, 12:03:11 AM [error] Risco command error: TIMEOUT. Command: {"panelId":1,"commandId":1,"attempts":1,"crcOk":false,"commandStr":"RMT=XXXX","sentBuffer":{"type":"Buffer","data":[...]}}
where data is an array of random looking numbers. I know for a fact the access code and IP address are correct. What am I missing? Thanks!
