Risco alarm system
It does?
From official page:
Local (advanced)
The integration will connect locally to your system. No dependency on the cloud, and instantaneous updates, but is harder to set up. You will need the panel access code (default 5678) to your system, this access code is NOT the same as the installer/subinstaller code, and with older models, you might need to either disconnect your system from the cloud, or set up a proxy that will allow you to connect both locally and via the cloud.
Still cant connect, not sure how to set it up, theres no doc.
Yes? The docs say that you need to setup a proxy…
Cause it isnt there… :slight_smile:
As I said before, the proxy is only available in the addon
Check error logs, and create a GitHub issue
Never got local to work on the official integration either. Went back to the add-on because of that, which works like a charm.
I think you filled in the config correctly (at least that is what I tried as well).
What’s in the logs? Maybe the owner can help? It should work, lots of people are using it…
Maybe you are using the wrong panel code, I know the addon is doing a brute force , I don’t thing the integration does that
Maybe you guys have a board not supported by default, you really need to enable debug and create GitHub issue, the owner is very helpfulll, so it can be fixed!
It’s a very new integration, it could have small bugs…
i dont see anything in the log
Do you know to who i need to talk to?
Would be strange if board is not supported, if it works with the addon
Enable debug , then you see everything
I reported an issue on github
Ok, but upload logs by enable debug mode on the component, have a look at the logger integration how to do it, it will be the first question anyway
i enabled debug logging, however im not sure to just share the complete logs
Can you help me out too pls
see Risco cannot connect local panel (advanced) · Issue #97463 · home-assistant/core · GitHub
It would fix it for you too
Yes, I have some time next week to try and debug again!
Just post the relevant part only , just enable debug only for the risco integration, the rest is not necessary
i did :slight_smile: hehe
Ok still got the warning clock.
I looked at my clock on my risco device and it seems its 2/8/2022
So a year back.
Probably thats the cause?
I tried to change it back, but i cant?
Is this cause i’m local now, and not cloud anymore.
I cant change time?
You should be able to change the date/time on the panel.
However my time is wrong as well. The date is correct, but when setting the time, it is off by 10 minutes after a while.
Probably because it can’t connect to an NTP server because the board only allows 1 IP connection (being Home Assistant). So you can set the clock, but it won’t sync automatically. And just like my microwave clock it messes up time after a while. Annoying, but not blocking.
I read in another topic that the clock timeout error can be safely ignored.
Oh it can be ignored? nice thx
Will do then :slight_smile: Would rock if the clock could sync with HA :slight_smile:
just setup a local NTP server on your panel, and make sure you define the correct timezone
if you have old socket , with 1 connection, you can use the NTP on it, so all local connections can do it, cause you disabled cloud, so it can again connect to internet
thats chinese for me :stuck_out_tongue:
