how can I force the panel selection?
I got 2 panels, the first one is currently offline and the second one is the one I use.
when I add my details to the 115beta integration it always picks the first panel as that’s the order they are in the Risco Cloud, and I don’t see a way to reorder them. They also have different PIN codes.
Can force the panel I want by referencing it by name on the config.yaml?
you mean like those?
2020-09-08 20:31:32 ERROR (MainThread) [custom_components.risco] Error fetching risco data:
2020-09-08 20:55:26 ERROR (MainThread) [custom_components.risco] Error fetching risco data:
yeah, have them too, i am playing with polling time, i had before like 1 or 2 sec, was too much i think, now i am testing 5
alltough those erros occurt, they dont have impact on your system
maybe only with an automation where you want to turn off a light, if noone is in a room since like 15min or something …
yeah, but i think those errors were there too with those other dockers, but probably didnt notice
but wait for 115.0 , then those logs have more details in it, then he can troubleshoot more
I have smoke detectors paired with the risco alarm.
However, i should have some more, but i cant get extra risco smoke detectors.
I probably would buy zigbee smoke detectors to add…
The question is, will i be able to let the alarm go off too if the zigbee smoke detectors, detect smoke too?
I dont know if the integration has the actual alarm box too as possible sensor to go off?
If you know what i mean…
still seeing the blank texts after updating to 115 and adding it over the official integrations.
anyone got the same problem? custom_components risco folder was of course removed before and rebooted.
yes removed the integration, rebooted, upgraded, installed risco. relealized i still had the custom components folder so i removed it completely, rebooted and then tried to install it again but still empy text fields.
Seems i have an issue, when I arm my risco (home) mode, it gives me an unavailable state or the state doesn’t change… When I arm away, there is no issue
Logger: homeassistant
Source: components/risco/alarm_control_panel.py:112
First occurred: 0:10:44 (2 occurrences)
Last logged: 0:11:44
Error doing job: Task exception was never retrieved
And
Logger: homeassistant.components.websocket_api.http.connection.140581836721936
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 0:11:19 (1 occurrences)
Last logged: 0:11:19
'NoneType' object is not iterable
