Roborock s7 maxV.
followed this amazing guide and theme:
🟣 Rounded - Dashboard guide - #2 by LE0N + the help of @CM000n user, i try to complete “Vacuum zones” card.
after i toggle which rooms i want to clean,we press “vacuum zones”
my problem is to implement the segments, as the creator of this section created this for another robot, so its customs yaml code with room id’s.
how can I implement this with room’s that we have from map extractor?
alias: Vacuuming of selection
icon: mdi:robot-vacuum
sequence:
- service: script.turn_on
entity_id: script.vacuum_clean_segments_message
variables:
segments: >-
** {{expand(“group.vacuum_rooms”) | selectattr(“state”,“eq”,“on”) |**
** map(attribute=“attributes.room_id”) | list | to_json}}**
iterations: >-
{{states(‘input_number.general_robot_vacuum_cleaner_zone_repetitions’)}} - if:
- condition: state
entity_id: input_boolean.living_room_select_cleaning
state: “on”
then: - service: input_datetime.set_datetime
entity_id: input_datetime.living_room_last_cleaned
date: “{{ now().strftime(’%Y-%m-%d’) }}”
- condition: state
- if:
- condition: state
entity_id: input_boolean.kitchen_select_cleaning
state: “on”
entity_id: input_datetime.kitchen_last_cleaned
- condition: state
- if:
- condition: state
entity_id: input_boolean.bed_room_select_cleaning
state: “on”
entity_id: input_datetime.bed_room_last_cleaned
- condition: state
- if:
- condition: state
entity_id: input_boolean.toilet_select_cleaning
state: “on”
entity_id: input_datetime.toilet_last_cleaned
- condition: state
- if:
- condition: state
entity_id: input_boolean.bath_room_select_cleaning
state: “on”
entity_id: input_datetime.bath_room_last_cleaned
- condition: state
- if:
- condition: state
state: “on”
- condition: state
- if:
- condition: state
entity_id: input_boolean.hallway_select_cleaning
state: “on”
entity_id: input_datetime.hallway_last_cleaned
- condition: state
- if:
- condition: state
entity_id: input_boolean.guest_room_select_cleaning
state: “on”
entity_id: input_datetime.guest_room_last_cleaned
- condition: state
- if:
- condition: state
entity_id: input_boolean.office_select_cleaning
state: “on”
entity_id: input_datetime.office_last_cleaned
- condition: state
- service: input_boolean.turn_off
entity_id:
- input_boolean.living_room_select_cleaning
- input_boolean.kitchen_select_cleaning
- input_boolean.bed_room_select_cleaning
- input_boolean.bath_room_select_cleaning
- input_boolean.toilet_select_cleaning
- input_boolean.hallway_select_cleaning
- input_boolean.guest_room_select_cleaning
- input_boolean.office_select_cleaning
data: {} - service: input_number.set_value
value: 1
entity_id: input_number.general_robot_vacuum_cleaner_zone_repetitions
mode: single
