Roborock room cleaning
Hi!
I’m using latest 2023.7.0 and I’m trying to make a simple script to clean one room.
I followed this guide and everything worked as expected except the repeat option that is not working, no matter what I choose ( 1, 2 or 3 ) it only vacuum/mop once.
This is my script:
alias: Limpar quarto principal
sequence:
  - service: vacuum.send_command
      command: app_segment_clean
      params:
        - segments:
            - 19
        - repeat: 3
      entity_id: vacuum.roborock_s7
mode: single
icon: mdi:robot-vacuum
The repeat function in the automation as I understand it is used for cross hatch cleaning of the same room, and I understand it the levels are as follows:
Repeat 1: Back and forth in one direction
Repeat 2: Back and forth and back in the perpendicular path as well
Repeat 3: It goes over the room again.
Here is a good thread on the topic. Repeats with Roborock
If you want it to run more than once with the same pattern then call your script at 2 different times.
I understand what it does, the problem is that no matter the value I put on repeat, it always do only 1 clean, no perpendicular and no repeat.
I already tried:
- repeat: 2
And:
- repeat: “2”
But it makes no difference.
Here is my automation and it works:
alias: Vacuum-Vacuum Common Areas Everyday
description: ""
  - platform: time
    at: "09:00:00"
    enabled: true
condition: []
  - choose:
      - conditions: []
        sequence:
              command: set_water_box_custom_mode
              params: 200
          - service: vacuum.set_fan_speed
              fan_speed: balanced
              params:
                - segments:
                    - 24
                    - 25
                    - 18
                    - 19
                    - 16
                    - 22
                    - 17
                  repeat: 2
          - service: notify.mobile_app_XXX
              message: Everyday Vacuuming has started
              title: SUCCESS!!
          - service: notify.mobile_app_YYY
              title: SUCCESS!!
mode: single
Thanks, I added to my automations to see if it makes any difference instead of using scripts.
But I already found a difference, you are not using a dash before the command and I am, because it’s what is on the guide :confused:
              params:
                - segments:
                    - 24
                    - 25
                    - 18
                    - 19
                    - 16
                    - 22
                    - 17
                  repeat: 2
      params:
        - segments:
            - 19
        - repeat: 3
I’ll report tomorrow if it worked or not, now it’s too late to test it :sleeping_bed:
That’s why you should always post your config when asking questions.
That dash is very important in YAML: it indicates an item in a list. What you did before is to put repeat with segments in a list instead of on its own.
Thanks, but I posted on a the first post. But I didn’t know that. TIL :ok_hand:t3:
My kid is still sleeping no chance to test it yet
Yes, I can confirm that was the dash before the repeat that was breaking the script.
I am trying to create a button that will start cleaning in selected rooms. The rooms are selected based on toggles that I have created for individual rooms.
The problem I am facing is how to template the list of segments/rooms while calling the service. I have been fighting with that for several hours but can’t make it work:(
If I call the service from the below code in Developer tools it works but I cannot save the card as is. I need to add - segments: > but then the service doesn’t work.
Can anyone please help?
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            entity: vacuum.roborock_s7_2
            tap_action:
              action: call-service
                params:
                  - segments:
                      {% if is_state('input_boolean.vacuum_bedroom', 'on') %}
                        - 19
                      {% else %} {% endif %}
                      {% if is_state('input_boolean.vacuum_bathroom', 'on') %}
                        - 24
                    repeat: 2
                entity_id: vacuum.roborock_s7_2
            icon: mdi:playlist-play
            card_mod:
              style: |
                ha-card {
                  justify-content: center;
As far as I understood there is no way to create a list with a template inside the card. I ended up creating a script and calling that from the card.
can you post your script please - I’m trying to do the same thing. Many thanks
@Neep Here you go. You need to get your own [room IDs].
alias: Vacuum Selected Rooms
sequence:
      params:
        - segments: >-
            {%- set ns = namespace(ids=[]) %} {%- if
              {% set ns.ids = ns.ids + [24] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_bedroom', 'on')
              {% set ns.ids = ns.ids + [19] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_hallway', 'on')
              {% set ns.ids = ns.ids + [16] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_kitchen', 'on')
              {% set ns.ids = ns.ids + [22] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_living_room',
            'on') %}
              {% set ns.ids = ns.ids + [23] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_technical', 'on')
              {% set ns.ids = ns.ids + [18] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_toilet', 'on') %}
              {% set ns.ids = ns.ids + [17] %}
            {%- endif %} {%- if is_state('input_boolean.vacuum_room',
            'on') %}
              {% set ns.ids = ns.ids + [20] %}
            {%- endif %} {{ ns.ids }}
          repeat: "{{ states('input_number.vacuum_repeat_count') | int }}"
mode: single
icon: mdi:robot-vacuum```
hero - thank you
