2019-10-18 20:08:54 WARNING (MainThread) [homeassistant.components.http.auth] legacy_api_password support has been enabled.
2019-10-18 20:08:57 ERROR (SyncWorker_12) [pyHS100.discover] Got exception Communication error
File "/usr/local/lib/python3.7/site-packages/pyHS100/smartdevice.py", line 117, in _query_helper
request=request,
File "/usr/local/lib/python3.7/site-packages/pyHS100/protocol.py", line 60, in query
length = struct.unpack(">I", chunk[0:4])[0]
struct.error: unpack requires a buffer of 4 bytes
File "/usr/local/lib/python3.7/site-packages/pyHS100/discover.py", line 57, in discover
devices[ip] = device_class(ip)
File "/usr/local/lib/python3.7/site-packages/pyHS100/smartstrip.py", line 43, in __init__
children = self.sys_info["children"]
File "/usr/local/lib/python3.7/site-packages/pyHS100/smartdevice.py", line 186, in sys_info
return defaultdict(lambda: None, self.get_sysinfo())
File "/usr/local/lib/python3.7/site-packages/pyHS100/smartdevice.py", line 196, in get_sysinfo
return self._query_helper("system", "get_sysinfo")
File "/usr/local/lib/python3.7/site-packages/pyHS100/smartdevice.py", line 120, in _query_helper
raise SmartDeviceException('Communication error') from ex
pyHS100.smartdevice.SmartDeviceException: Communication error
2019-10-18 20:09:05 ERROR (SyncWorker_12) [roomba.roomba.Roomba] Error: [Errno 104] Connection reset by peer
2019-10-18 20:09:05 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for files which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall google.found_calendar (<obfuscated>): kind=calendar#calendarListEntry, etag="<obfuscated>", id=<obfuscated>@group.calendar.google.com, summary=TV Auto Tune, description=For Auto Tuning TV, timeZone=America/New_York, colorId=24, backgroundColor=#a47ae2, foregroundColor=#000000, accessRole=owner, defaultReminders=[], conferenceProperties=allowedConferenceSolutionTypes=['eventHangout'], track=False>
File "/usr/src/homeassistant/homeassistant/core.py", line 1241, in _safe_execute
await self._execute_service(handler, service_call)
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
await self._hass.async_add_executor_job(handler.func, service_call)
concurrent.futures._base.CancelledError
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component tts
File "/usr/src/homeassistant/homeassistant/setup.py", line 167, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/tts/__init__.py", line 179, in async_setup
await asyncio.wait(setup_tasks)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
return await _wait(fs, timeout, return_when, loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall group.set (<obfuscated>): object_id=all_devices, visible=False, name=all devices, entities=[]>
File "/usr/src/homeassistant/homeassistant/core.py", line 1258, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 238, in locked_service_handler
await groups_service_handler(service)
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 267, in groups_service_handler
**extra_arg,
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 488, in async_create_group
await component.async_add_entities([group], True)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 252, in async_add_entities
await asyncio.wait(tasks)
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform ecobee
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 435, in wait_for
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component switch
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 566, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 534, in run_forever
self._run_once()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 1771, in _run_once
handle._run()
File "/usr/local/lib/python3.7/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/components/roomba/vacuum.py", line 108, in async_setup_platform
await hass.async_add_job(roomba.connect)
File "/usr/local/lib/python3.7/site-packages/roomba/roomba.py", line 283, in connect
sys.exit(1)
SystemExit: 1
File "/usr/src/homeassistant/homeassistant/components/switch/__init__.py", line 68, in async_setup
await component.async_setup(config)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 121, in async_setup
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform files
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform time_date
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component sensor
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 54, in async_setup
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.setup] Error during setup of component light
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 261, in async_setup
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall group.set (<obfuscated>): object_id=all_scripts, name=all scripts, visible=False, entities=['script.home_audio_annoucement', 'script.kuna_image_notification', 'script.roomba_status_announcement', 'script.tv_browse_select', 'script.tv_browse_start', 'script.tv_browse_stop', 'script.becca_button_for_light', 'script.becca_button_for_music']>
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
File "/usr/src/homeassistant/homeassistant/components/group/__init__.py", line 237, in locked_service_handler
async with service_lock:
File "/usr/local/lib/python3.7/asyncio/locks.py", line 92, in __aenter__
await self.acquire()
File "/usr/local/lib/python3.7/asyncio/locks.py", line 192, in acquire
await fut
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform flux_led
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform command_line
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform version
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [custom_components.kuna] Error while authenticating Kuna:
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall google.scan_for_calendars (c:79cefcfd25174cea91db7b440247756a)>
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
2019-10-18 20:09:06 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform template
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
await waiter
self.run_forever()
self._run_once()
handle._run()
sys.exit(1)
SystemExit: 1
