I’m new Home Assistant and trying to add all the things , including my roomba (i3+), but it can’t seem to pull the password either manually or automatically. I’ve followed the directions provided (iRobot Roomba and Braava - Home Assistant ) and found some links with references to vastly instances of Home Assistant (not sure how solutions like docker exec or pip translate to HAOS).
Link to similar problems:
I just got a new Roomba i6 and I was delighted to see that there’s a HA integration for it. Unfortunately when I attempted to add the integration and set up my Roomba, I got errors during installation.
When I click “Add Integration” it seems to start the installation process successfully. During the “Connect Device” process, it is able to find my new Roomba so I can select it as a host from the drop-down list. It then asks me to hold down the home button on the Roomba and then hit submit. After…
Recently, I moved my HA container installation to an HA-Yellow box. Most everything works correctly except the iRobot integration. I cannot get it to connect to the Roomba. I have the password that I use in my Docker install where it works correctly. Imagining that the password could be fungible, I went through the retrieval procedure again and the password is identical. The message received is:
‘The password could not be retrieved from the device automatically. Please make sure that the iRobot…
My Home Assistant info:
note that I’m using HAOS & it reports up to date.
Core 2024.7.2
Supervisor 2024.06.2
Operating System 12.4
Frontend 20240710.0
Let me know what else I can provide or try.
bjm
(Brent (the Other Other Kiwi))
November 22, 2024, 6:46am
2
How did you get on with this? I just got a really cheap , new, i2 and i cant integrate it
Unfortunately I don’t have anything useful to report at the moment as I’m stuck on another problem:
But once i get that up and running, I’ll certainly give this another shot.
bjm
November 25, 2024, 7:56am
4
I got the i2 added in the end, really easy and assume it will work with others, try this…
Awesome, glad you found something & we’ll see if I end up needing it once I’m there again.
