🟣 Rounded - Dashboard guide
I did the card-mod update but how to i clear the cach of the android app? In the phone settings?
There is such a thing as google… :wink:
Ok i managed to clear the cach and it works again… Thanks:)
Happy to help. Always first recourse if suddenly something in the front end looks dramatically different. And almost always required after a card mod update. Just FYI :slight_smile: :slight_smile:
Good to know :+1:
Please see
https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://github.com/lovelace-rounded/theme&ved=2ahUKEwi-xefmufiBAxXROewKHXQsClIQFnoECAcQAQ&usg=AOvVaw1x9uWn9YplmZ3AV94DpdX2
Install versus HACS ?
Interesting! Is the repo created by @LE0N (the inventor of rounded) or does he know about it?
If yes, the initial post in this thread should possibly be revised :wink:
Hello, i’m not sure how to get the temperature slider.
I get the brightness ok. But what do I have to change to the code to get the color_temp ?
Just replace colorMode: brightness with colorMode: temperature - that did it for me.
Screenshot 2023-10-18 at 00-00-58 Visão Geral – Home Assistant
I want to spin fan icon when “Ventoinha” is on, any idea ?
Code :
type: custom:button-card
entity: switch.ventoinha
show_icon: false
styles:
  card:
    - border-radius: 25px
    - border-style: none
    - box-shadow: 0px 0px 10px -9px black
  grid:
    - grid-template-areas: '"icon_cells" "n" "button"'
    - grid-template-columns: 1fr
    - grid-template-rows: 1fr min-content min-content
  custom_fields:
    icon_cells:
      - justify-self: start
      - margin-top: 12px
      - margin-left: 15px
  name:
    - font-size: 90%
    - font-weight: bold
    - margin-top: 6px
    - margin-left: 15px
custom_fields:
  icon_cells: |
      return `<ha-icon
        icon="mdi:fan"
        style="width: 25px; height: 25px; color: auto;">
       </ha-icon>
  button:
    card:
      entity: switch.volante_switch
      show_icon: false
      show_name: false
      styles:
        card:
          - margin-top: '-4%'
          - margin-bottom: '-5%'
          - background-color: transparent
        grid:
          - grid-template-areas: '"state icon_cells"'
          - grid-template-columns: min-content 1fr
          - grid-template-rows: min-content
        custom_fields:
          state:
            - align-self: middle
            - font-size: 12px
            - filter: opacity(50%)
            - margin-left: 15px
            - margin-top: 1.6px
          icon_cells:
            - justify-self: end
            - align-self: start
            - margin-right: 15px
            - width: 45px
      custom_fields:
        icon_cells: |
           var state = states['switch.ventoinha'].state;
           if(state == "on")
            return `<ha-icon
            icon="mdi:toggle-switch"
            style="color: #59CE8F;">
            </ha-icon>
           else
            return `<ha-icon
            icon="mdi:toggle-switch-off"
            style="color: auto;">
            </ha-icon>
        state: |
            var power = states['sensor.ventoinha_power'].state
           if(state == "on")
            return `<span>${power}W</span>
           else
            return `<span>Desligado</span>
Thanks !
Hi @Diggs, it seems that your code was not formatted properly and some elements and indentations are missing. Can you try again to post the code in the correct yaml format?
Hi, code is now formated.
Nooo answere Nobody … nsa files
Someone added with Rounded theme, the bubble card?
how you change the color of the background if this card? that will not be like Brightness
Hi everyone!
I would really appreciate it if someone could help me with a problem that I can’t solve or understand. FYI I the noob of the noobs so…don’t laugh xD
As you can see in the image below, I have a problem with those cards when viewing them on a iPhone 11. One thing I learned is if I remove all the icons I don’t have any problem.
The code below is fot the second group of cards. I’m using the Rounded theme.
Thank you all in advance!
custom_fields:
  badge:
    card:
      name: '[[[return states["weather.praia_de_miramar"].state]]]'
      label: |
           const temperature = states["weather.praia_de_miramar"].attributes.temperature;
           const humidity = states["weather.praia_de_miramar"].attributes.humidity;
           return `<ha-icon icon="mdi:thermometer" style="height:17px;"></ha-icon>${temperature} °C <ha-icon icon="mdi:water-percent" style="height:17px;"></ha-icon>${humidity} %`;
      show_label: true
      show_icon: true
      show_name: false
      entity: weather.praia_de_miramar
      tap_action:
        action: more-info
        haptic: medium
      styles:
        grid:
          - grid-template-areas: '"i l"'
          - grid-template-columns: 1fr fr;
          - grid-template-rows: min-content;
          - justify-content: center;
        icon:
          - grid-area: i;
          - height: 40px;
          - margin-right: 1px
          - margin-left: 9px
          - color: var(--contrast6)
        card:
          - font-family: In case of a custom font, otherwise you can remove this line
          - padding: 0.2px 0.2px
          - font-size: 12px
          - line-height: 18px
          - font-weight: 500
          - background: var(--contrast20)
          - text-align: left;
        name:
          - color: var(--contrast1)
        label:
          - color: var(--contrast10)
          - margin-right: 18px
styles:
  grid:
    - grid-template-areas: '"n" "badge"'
  card:
    - background: none
    - padding: 16px 0
    - '--mdc-ripple-press-opacity': 0
  name:
    - font-size: 32px
    - color: var(--contrast20)
  custom_fields:
    badge:
      - margin: 16px auto 0 auto
      - '--mdc-ripple-press-opacity': 0.5
For your state, when it’s on, you just need to add a simple line;
- animation: rotating 1s linear infinite
This will then make it spin only when it’s on. So my card is set up as below;
label: Bedroom Fan
show_icon: true
show_label: true
show_name: false
show_state: true
entity: fan.jakes_bedroom_fan
tap_action:
  action: toggle
  haptic: medium
hold_action:
  action: more-info
  haptic: medium
styles:
  grid:
    - grid-template-areas: '"l" "s" "button"'
  card:
    - background: var(--contrast2)
    - font-family: Montserrat
    - padding: 13px
    - max-width: 100%
  img_cell:
    - width: 64px
  label:
    - font-size: 14px
    - margin: 4px 0 8px 0
    - font-weight: 600
  state:
    - font-size: 10px
    - margin: 4px 0 2px 0
    - color: var(--black)
    - text-transform: uppercase
    - font-weight: 200
state:
  - value: 'off'
    styles:
      card:
        - background: var(--blue)
      icon:
      label:
      name:
  - value: 'on'
    styles:
      card:
        - background: var(--green)
      icon:
      name:
      label:
Hello Guys,
I have an issue with big gaps between rows in a grid. The gap is way bigger then the card which is inside of the column:
All cards are wrapped in a grid layout, this is my code:
#Detailed Lighes
      - columns: 2
        type: grid
        cards:
          #Livingroom AmbientLights
          - type: custom:button-card
            icon: mdi:sofa-single
            entity: light.wohnzimmer
            tap_action:
              action: toggle
              haptic: medium
            hold_action:
              action: more-info
              haptic: medium
            custom_fields:
              slider:
                card:
                  type: custom:my-slider-v2
                  styles:
                    container:
                      - background: none
                      - border-radius: 100px
                      - overflow: visible
                    card:
                      - height: 16px
                      - padding: 0 8px
                      - background: |
                            if (entity.state == "on") return "linear-gradient(90deg, rgba(255,255,255, 0.3) 0%, rgba(255,255,255, 1) 100%)";
                            else return "var(--contrast4)";
                    track:
                      - overflow: visible
                      - background: none
                    progress:
                      - background: none
                    thumb:
                      - background: |
                            if (entity.state == "on") return "var(--black)";
                            if (entity.state == "off") return "var(--contrast20)";
                            else return "var(--contrast8)";
                      - top: 2px
                      - right: "-6px"
                      - height: 12px
                      - width: 12px
            styles:
              grid:
                - grid-template-areas: '"i" "n" "slider"'
              card:
                - padding: 16px
                - margin: 0px
                - "--mdc-ripple-press-opacity": 0
              img_cell:
                - width: 24px
              icon:
                - width: 24px
                - height: 24px
                - color: var(--contrast8)
              name:
                - font-size: 14px
                - margin: 4px 0 12px 0
            state:
              - value: "on"
                styles:
                  card:
                    - background: var(--yellow)
                  icon:
                  name:
              - value: "off"
                styles:
                  icon:
                  name:
          #Livingroom Ambient Lights
            entity: light.wohnzimmer_deckenlampe
            tap_action:
              action: toggle
              haptic: medium
            hold_action:
              action: more-info
              haptic: medium
            custom_fields:
              slider:
                card:
                  styles:
                    container:
                      - background: none
                      - overflow: visible
                    card:
                      - height: 16px
                      - padding: 0 8px
                      - background: |
                    track:
                      - overflow: visible
                      - background: none
                    progress:
                      - background: none
                    thumb:
                      - background: |
                      - top: 2px
                      - right: "-6px"
                      - height: 12px
                      - width: 12px
            styles:
              grid:
              card:
                - padding: 16px
                - margin: 0px
              img_cell:
                - width: 24px
              icon:
                - width: 24px
                - height: 24px
              name:
                - font-size: 14px
            state:
              - value: "on"
                styles:
                  card:
                  icon:
                  name:
              - value: "off"
                styles:
                  icon:
                  name:
            tap_action:
              action: toggle
              haptic: medium
            hold_action:
              action: more-info
              haptic: medium
            custom_fields:
              slider:
                card:
                  styles:
                    container:
                      - background: none
                      - overflow: visible
                    card:
                      - height: 16px
                      - padding: 0 8px
                      - background: |
                    track:
                      - overflow: visible
                      - background: none
                    progress:
                      - background: none
                    thumb:
                      - background: |
                      - top: 2px
                      - right: "-6px"
                      - height: 12px
                      - width: 12px
            styles:
              grid:
              card:
                - padding: 16px
                - margin: 0px
              img_cell:
                - width: 24px
              icon:
                - width: 24px
                - height: 24px
              name:
                - font-size: 14px
            state:
              - value: "on"
                styles:
                  card:
                  icon:
                  name:
              - value: "off"
                styles:
                  icon:
                  name:
Do you have any clue what the reason for those big gaps could be?
Best
Max
Try a grid configuration with square: false:
  - type: "grid"
    columns: 2
    square: false
    cards:
That did the trick for me, thanks a lot Simon!
