It worked, thank you @matmann
Hi all. I do have seen the template from panhans on Github and wanted to integrate this.
However I’ll not be able to find the ui-lovelace.yaml as I have been using the editor most times.
One part of the Template are cards that are moved to a folder and should be included into the ui-lovelace.yaml. If I try to add this to the Dashboard with button_card_templates: !include_dir_merge_named “ui/templates” I’ll get the error that this is not possible.
Any other suggestion to add this?
I wanted to avoid creating the templates manually from within Home Assistant.
Thanks in advance.
(post deleted by author)
Redirecting to template files/folders just works if have your dashboard in yaml mode and not visual (as most have).
You need to add the button code in the raw dashboard at the very top.
