By the way. You do not need to add the scaler, width and color to the theme. You can apply it in button card.
I ve just noticed the mistake. Usennn
:host {
--assistant-width: 50;
--assistant-scaler: calc(var(--assistant-width); / 200);
--assistant-color: white;
so here the complete code.
type: custom:button-card
show_name: false
show_state: false
show_icon: false
show_label: false
tap_action:
action: none
styles:
grid:
- grid-template-areas: '"."'
- grid-template-columns: min-content
- grid-template-rows: min-content
card:
- padding: 32px
- background: var(--background-color)
- height: max-content
custom_fields:
custom_html: |
return `
<div class="assistant-container">
<div id="assistant">
<div class="assistant-dot"></div>
</div>
<div id="assistant-corner"></div>
<div id="assistant-antenna">
<div id="assistant-beam"></div>
<div id="assistant-beam-pulsar"></div>
</div>
</div>
extra_styles: |
:host {
--assistant-scaler: calc(var(--assistant-width) / 200);
.assistant-container {
margin: auto;
position: absolute;
bottom: 0;
left: 0;
top: 0;
right: 0;
height: calc(200px * var(--assistant-scaler));
width: calc(200px * var(--assistant-scaler));
animation: up-down 7.5s infinite ease-in-out;
background-color: var(--background-color);
.assistant-container #assistant {
margin: auto;
position: absolute;
bottom: 0;
left: 0;
top: 0;
right: 0;
width: calc(150px * var(--assistant-scaler));
height: calc(85px * var(--assistant-scaler));
border: calc(12px * var(--assistant-scaler)) solid var(--assistant-color);
border-radius: 5rem;
.assistant-container #assistant-corner {
margin: auto;
position: absolute;
bottom: 0;
left: 0;
top: 0;
right: 0;
top: calc(105px * var(--assistant-scaler));
left: calc(-65px * var(--assistant-scaler));
width: 0;
height: 0;
border-left: calc(20px * var(--assistant-scaler)) solid transparent;
border-right: calc(20px * var(--assistant-scaler)) solid transparent;
border-top: calc(25px * var(--assistant-scaler)) solid var(--assistant-color);
transform: rotate(140deg);
.assistant-container #assistant-antenna {
margin: auto;
position: absolute;
bottom: 0;
left: 0;
top: 0;
right: 0;
top: calc(-125px * var(--assistant-scaler));
height: calc(20px * var(--assistant-scaler));
width: calc(10px * var(--assistant-scaler));
background-color: var(--assistant-color);
animation: antenna-appear 7.5s infinite ease-in-out;
.assistant-container #assistant-antenna #assistant-beam {
position: absolute;
top: calc(-12.5px * var(--assistant-scaler));
left: calc(-5px * var(--assistant-scaler));
width: calc(20px * var(--assistant-scaler));
border-radius: 50%;
animation: beam-appear 7.5s infinite ease-in-out;
.assistant-container #assistant-antenna #assistant-beam-pulsar {
position: absolute;
border-radius: 50%;
animation: beam-pulsar-appear 7.5s infinite ease-in-out;
.assistant-container .assistant-dot {
height: calc(17.5px * var(--assistant-scaler));
width: calc(17.5px * var(--assistant-scaler));
margin: auto;
position: absolute;
bottom: 0;
left: 0;
top: 0;
right: 0;
border-radius: 50%;
animation: pulse-outer 7.5s infinite ease-in-out;
.assistant-container .assistant-dot:nth-child(2) {
left: 0;
animation: pulse-inner 7.5s infinite ease-in-out;
animation-delay: 0.2s;
.assistant-container .assistant-dot:nth-child(3) {
left: calc(65px * var(--assistant-scaler));
animation-delay: 0.4s;
@keyframes pulse-inner {
0% { transform: scale(1); }
7.5% { transform: scale(1.5); }
15% { transform: scale(1); }
22.5% { transform: scale(1.5); }
30% { transform: scale(1); }
37.5% { transform: scale(1.5); }
45% { top: 0; transform: scale(1); height: calc(17.5px * var(--assistant-scaler)); border-bottom-left-radius: 50%; border-bottom-right-radius: 50%; transform: rotate(-370deg); }
50% { top: calc(22.5px * var(--assistant-scaler)); height: calc(10px * var(--assistant-scaler)); border-top-left-radius: 50%; border-top-right-radius: 50%; border-bottom-left-radius: 3rem; border-bottom-right-radius: 3rem; transform: rotate(10deg); }
55% { transform: rotate(-10deg); }
60% { transform: rotate(10deg); }
65% { transform: rotate(-10deg); }
85% { top: calc(22.5px * var(--assistant-scaler)); height: calc(10px * var(--assistant-scaler)); border-top-left-radius: 50%; border-top-right-radius: 50%; border-bottom-left-radius: 3rem; border-bottom-right-radius: 3rem; transform: rotate(0deg); }
92.5% { top: calc(22.5px * var(--assistant-scaler)); height: calc(10px * var(--assistant-scaler)); border-top-left-radius: 50%; border-top-right-radius: 50%; border-bottom-left-radius: 2.5rem; border-bottom-right-radius: 2.5rem; transform: rotate(0deg); }
100% { top: 0; height: calc(17.5px * var(--assistant-scaler)); border-radius: 50%; transform: rotate(-360deg); }
@keyframes pulse-outer {
37.5% {transform: scale(1.5); }
45% { transform: scale(1); height: calc(17.5px * var(--assistant-scaler)); }
55% { tranform: scale(1); height: calc(5px * var(--assistant-scaler)); }
60% { height: calc(17.5px * var(--assistant-scaler)); }
75% { height: calc(17.5px * var(--assistant-scaler)); }
80% { tranform: scale(1); height: calc(5px * var(--assistant-scaler)); }
85% { height: calc(17.5px * var(--assistant-scaler)); }
100% { height: calc(17.5px * var(--assistant-scaler)); }
@keyframes antenna-appear {
0% { visibility: hidden; top: calc(-100px * var(--assistant-scaler)); height: 0; }
50% { visibility: hidden; top: calc(-100px * var(--assistant-scaler)); height: 0; }
55% { visibility: visible; top: calc(-125px * var(--assistant-scaler)); height: calc(20px * var(--assistant-scaler)); }
95% { visibility: visible; top: calc(-125px * var(--assistant-scaler)); height: calc(20px * var(--assistant-scaler)); }
100% { top: calc(-100px * var(--assistant-scaler)); height: 0; }
@keyframes beam-appear {
0% { visibility: hidden; top: calc(-12.5px * var(--assistant-scaler)); height: 0; }
50% { visibility: hidden; top: calc(-12.5px * var(--assistant-scaler)); height: 0; }
55% { visibility: visible; top: calc(-12.5px * var(--assistant-scaler)); height: calc(20px * var(--assistant-scaler)); width: calc(20px * var(--assistant-scaler)); }
100% { visibility: visible; top: calc(-12.5px * var(--assistant-scaler)); height: calc(20px * var(--assistant-scaler)); width: calc(20px * var(--assistant-scaler)); }
@keyframes beam-pulsar-appear {
55% { visibility: visible; top: calc(-12.5px * var(--assistant-scaler)); left: calc(-5px * var(--assistant-scaler)); height: calc(20px * var(--assistant-scaler)); width: cal(20px * var(--assistant-scaler)); opacity: 1; }
65% { top: calc(-25px * var(--assistant-scaler)); left: calc(-15px * var(--assistant-scaler)); height: calc(40px * var(--assistant-scaler)); width: calc(40px * var(--assistant-scaler)); opacity: 0; visibility: visible; }
74% { visibility: hidden; opacity: 0; }
75% { visibility: visible; top: calc(-12.5px * var(--assistant-scaler)); left: calc(-5px * var(--assistant-scaler)); height: calc(20px * var(--assistant-scaler)); width: calc(20px * var(--assistant-scaler)); opacity: 1; }
85% { top: calc(-25px * var(--assistant-scaler)); left: calc(-15px * var(--assistant-scaler)); height: calc(40px * var(--assistant-scaler)); width: calc(40px * var(--assistant-scaler)); opacity: 0; visibility: visible; }
94% { visibility: hidden; opacity: 0; }
100% { visibility: hidden; opacity: 0; }
@keyframes up-down {
0% { transform: translate(0); }
2.5% { transform: translate(0, 2%); }
25% { transform: translate(0); }
37.5% { transform: translate(0, 2%); }
50% { transform: translate(0); }
62.5% { transform: translate(0, 2%); }
75% { transform: translate(0); }
87.5% { transform: translate(0, 2%); }
100% { transform: translate(0); }
